Why Can't I Edit My First Post Anymore
   / Why Can't I Edit My First Post Anymore #2
There is a time limit on the ability to edit a post. I'm not sure about that limit -- maybe it's 24 hours. If you want to add or modify your original post, "Reply with Quote" and clarify as needed.
Steve
   / Why Can't I Edit My First Post Anymore #3
Steve
Yep, its 24 hours. If you need to to remove info, you can report the post (click the "Report Post" icon (
) in the bottom left corner of the post and ask the moderators to change/remove the info.
Aaron Z
Okay thanks!
   / Why Can't I Edit My First Post Anymore #5
Steve
I wonder Steve if you can still delete at 1439 minutes? :D
   / Why Can't I Edit My First Post Anymore #6
Editing/Deleting is available for 24 hours, so as long as the server gets your "save" command before 1439:59, you should be good.
Aaron Z
IRGC40 High-End Mini Golf Cart (A53316)
IRGC40 High-End...
Advance Advolution 20BT Floor Cleaner (A47477)
Advance Advolution...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
200356 (A51406)
200356 (A51406)
New Hay Saver Horse Round Bale Feeder (A50775)
New Hay Saver...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
