CAV Injector Pump Leak
   / CAV Injector Pump Leak #1
ezrider93
Randleman, NC
Deutz 4006, International AI, Massey Ferguson 135
:confused:[SIZE=4]My Massey Ferguson 135 has a leak on the injector pump. It's on the banjo fitting that feeds the # 2 cylinder. I have tightened it as much as I dared but it still drips while running. Any suggestions on how to leak-proof a banjo fitting?[/SIZE]
   / CAV Injector Pump Leak #2
Try a new copper washer.
   / CAV Injector Pump Leak #3
X2...
   / CAV Injector Pump Leak #4
Did it work? I have a Massey MF 25 with a leak st the injection pump. Wanted to know if yours was just a new copper seal at the injection pump.
   / CAV Injector Pump Leak #5
G'day those washer are a special steel washer not copper, copper ones do not last any good injector/pump specialist should have them and sell them to you.
Jon
   / CAV Injector Pump Leak #6
copper will work fine
   / CAV Injector Pump Leak #7
Mine is leaking somewhere. Its in Michigan right now. I will check that banjo fitting.
What is a CAV injection pump? How do I know if that's what I have
   / CAV Injector Pump Leak #8
There should be a label on the pump that says what it is. CAV made rotary fuel pumps that were used on many different engines, they were bought out by Lucas and then Delphi.
FWIW, I looked up "mf25 injection pump" and all the rebuilt pumps and rebuild kits that came up were for a CAV.
   / CAV Injector Pump Leak #9
perfect! Could you attach a link to the websites you found. it is a A4.107 Perkins
   / CAV Injector Pump Leak #10
I just looked at pumps and repair kits on ebay. There should be several injection pump repair shops in Indy, just look some up and start calling around.
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
2011 Kubota ZG222 (A50123)
2011 Kubota ZG222...
DESK (A53843)
DESK (A53843)
