How many screws per board?
   / How many screws per board? #1
UpToNoGood
Magdalena NM / Datil NM
Bobcat CT2025
I am building a 20x20 garage this summer and I am in the planning/material gathering stage.
The outer walls will be ¾ plywood running long to cover more studs. Each board will cover 7 studs 16 on center. So my question is how many screws per stud? I was thinking 5 per stud each screw being 2 long. The boards will be staggered like bricks.
   / How many screws per board? #2
Plywood I generally fasten down on with 12-16" spacing between fasteners.
   / How many screws per board? #3
Code required me to nail 8d nails 4" on center around the perimeter and 12" on center in the field... screws not allowed.
   / How many screws per board? #4
Ultrarunner is correct. My inspectors will even frown if we go as much as 12" in the field.
Dave
   / How many screws per board? #5
What is the thinking behind screws not being allowed by code? Is it engineering or does the code need to be updated to allow them?
Kevin
   / How many screws per board? #6
I'm curious why your running the plywood that way?
   / How many screws per board? #7
Kevin
I was told nails are stronger than screws?
   / How many screws per board? #8
I was told code may require nails because they have better shear strength than screws.
   / How many screws per board? #9
The plywood is ran perpendicular to the framing for strength. This locks the framing together and helps to prevent "racking" of the walls during high winds, snow loads, etc.
   / How many screws per board? #10
It is all in how you define "stronger".
Nails are softer, will bend instead of breaking/failing, and usually are better for shear loads.
Screws are much harder, and usually take more effort to pull out.
So it all depends on the application. I would do what code requires in the area.
But I am sure hundreds are built with screws, and hundreds are built with nails, and neither will fail if used and installed properly.
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
