I've found one salvage machine at Cook's in Michigan. Their internet image shows many a part I can use but upon calling, found they had nothing. Their internet posted image shows machine as it arrived. As I got nothing from it basec on my lengthy list, I guess the machine is fairly well stripped. But for what it's worth, here is the link.
Phone: (269)673-5454
Cook Equipment Michigan
http://www.machinerytrader.com/listingsdetail/detail.aspx?OHID=8180455
Anyone got anuy other leads to salvage machines? Here is my list of wants, many of which I will procure new from John Deere dealer should I not find used:
Quick attach latches
Backhoe stabilizer hose
Plastic drive tube to front axle AM126394
Spare Ignition key RE183935
front wiper blade refill 24"
rear wiper blade refill 16"
Laurin Cab Heater Blower Switch Plug 153330100
Coolant overflow hose TY22559 cut to length
boom lock 15 AT178745 Pin 1
boom lock 16 T14083 Bumper 1
boom lock 17 W51421 Label 1
boom lock 18 AW31194 Stop 1
fuel filter gasket CH17154
radiator screen LVA11817
grille LVU11115 Screen 1
LVA14375 Instrument Cluster
boom hose rubber anchor clamp
fittings/hoses, convert to newer 110 loader hoses
Loader hard line 12 LVA14061 Oil Tube 2
rubber clamp for above T105774 Guide 2
hose 1 LVA14211 Hydraulic Hose 4
loader bucket quick tach mounting plate AW32978 Holder 1
loader bucket quick tach mounting plate AW32979 Holder 1
upper lh loader boom pin AW35298 Pin 1
upper rh loader boom pinAW35296 Pin 1
lower loader boom pin AW35297 Pin 2
hose 1/2 clamp, dipper stick, bucket hose on LH
backhose hose anchor half 18 T162003 Clamp
backhose hose anchor half 20 T187403 Clamp
LVA15252 Battery Box
LVA11062 Step (battery box cover)
LF Axle Seals
