I was able to try a couple of suggestions that you gave me yesterday to test the alternator on my tractor and here are the results:
1) checked battery before starting tractor: 12.3 volts after running tractor a couple of minutes 12.3 volts.
2) ran the tractor at different rpms and still 12.3 volts
3) cheched the voltage at the alternator (still had the battery connected so I don,t know if this reading means anything) 12.3 volts, Although at times,it seemed as if the voltage was fluctuating all over the place. I had no clips from the voltmeter, just hand held, so I'm not sure if I had a good contact at all times. I felt that I held the meter probes fairly consistent.
4) turned on the lights after the tractor was running - no noticable change in sound with engine. As if no load was applied.
5) no ammeter to check if needle would move
6) checked voltage between positive post on battery to negative post on starter and neg post on battery to pos post on starter and got 12.3volts both checks. not sure if I did this right because I should have come up with 0 volts to.5volts according to diesel lover.
I'm not sure what these measurments mean to any of you, but it seems as if the alternator is not working to me. any comments or suggestions would be welcome.
