JD 3038E vs Kubota L3200
   / JD 3038E vs Kubota L3200 #1
DFisher63
Somewhere else
JD 3038E
I know the comparisons get done to death, so please bear with me. Upon pricing, I have been shocked to find the JDs are less expensive. With that said, I can buy a JD 3038E for $1300 LESS than a Kubota L3200. I have seen the comparisons between 3032 and L3200, and 3038 and L3800, but in this case I am comparing different animals. I own 23 acres, but only 5 are cleared, mostly flat, and 3 will be cut with a rotary cutter. I will use a box scrape to tend a 200' drive, and one day a rotary tiller for gardening and deer plots. I'll use the loader for a variety of things, including moving mulch, gravel, etc. Most comparisons show the Kubota to be the better-built tractor. Bottom line is this: Would you pay more for the Kubota to get less horsepower?
Comparison stuff that matter to me (some merely my opinion):
JD has higher HP
JD has better HST pedal setup
JD has steering rods behind the axle (protected)
JD has better warranty (3 yrs vs. 2)
JD is $1300 cheaper (JD $18,500 vs Kubota $19,800) Big surprise for me!
Kubota has better hood design for easier maintenance
Kubota has quick disconnect loader
Kubota has concealed hydraulic lines to bucket (protected)
Kubota has 3 speed ranges instead of 2
Kubota has bigger fuel tank
Kubota has a drawbar standard
Kubota has cast iron rear end
Kubota is 450 lbs heavier
Which has the best resale is questionable to me. Dealers are both about 45 minutes away, and both seem very easy to work with. Neither are totally American made. Financing is same, except JD offers $1000 back if 2 implements bought, which if used (and I will), makes the JD $2300 cheaper. Your thoughts?
   / JD 3038E vs Kubota L3200 #2
The Kubota pricing you received is high. You can do better than that. Try Barlows or another dealer. I really don't like the aluminum final drive casting on the JD and the two speed hydro. The 450 lbs extra is your friend, and the Kubota is considered a light tractor. A Kioti, Mahindra or LS in that size class will be much heavier yet. This is a good thing in most usages. A Kioti CK35 will weigh a 1000 or so more than the Kubota, and have a 4 year powertrain warranty. If I had to choose between the Kubota and the JD I would choose the Kubota. But I would look at other brands if I were you. It looks like you have researched these two tractors thoroughly.
   / JD 3038E vs Kubota L3200 #3
Get a L3800 same tractor more horsepower, I almost bought a 3038E until I tested out the Kubota L3800. I use my L3800 for business and this tractor has done everything I have asked of it, worth the extra cash.
   / JD 3038E vs Kubota L3200 #4
I got my L3200 with front loader and R4 tires for $18400. L3800 would have been $19800.
I think the HST pedal setup is subjective -- I was used to the Deere arrangement, but running a Kubota for 2+ years has got me liking that better -- just seems more intuitive.
   / JD 3038E vs Kubota L3200 #5
I would tend to agree with this as well. I have the 2 pedal setup on my Kioti, and love it, but I also loved the single treadle pedal of the Kubota. It is just what you get used to. I have heard several people complain about the treadle pedal even after owning it for some time, but I got along fine with it. A few posters with disability's noted that the 2 pedal setup was easier on their ankles or they had trouble lifting their foot to go into reverse. I can certainly understand that situation, but for those of us that still have good articulation in our ankles, there is nothing inherently wrong with the treadle pedal, and it may be a hair faster to transition from forward to reverse as your foot is already on it.
Where did you get yours? The NC dealers (4 within an hour) are not coming close, and I really don't want to get one from several states away. If my price for the L3200 had been $18400, I would already have it.
   / JD 3038E vs Kubota L3200 #7
I just bought a new 3032E, tractor, loader, 5' rotary cutter, 6' blade, loaded rear tires, and i-match for $18,500 delivered to my house. The Kubota I was looking at was $18,300 just for the tractor and loader. It was a no brainer to buy the Deere. The 0% financing for 5 years was a nice feature also.
Current pricing, as of a minute ago, all with R4 tires:
JD 3032E with 305 FEL, $17,300
JD 3038E with 305 FEL, $18,500
Kubota L3200 with 524 FEL, $19,800.
   / JD 3038E vs Kubota L3200 #9
I got lucky, a dealer 80 miles away from me had 6 2013 3032E at a promotional price. It is my understanding they were trying to get market share in an area and that was their advertised price, so he had to sell it to me for that advertised price.The tractor and loader by itself was only $15,595. If you want to drive to Kansas I'm sure he will sell you one for the same price.
   / JD 3038E vs Kubota L3200 #10
I bought from Dubberly Tractor in Chester VA. But Barlow's out of Kentucky had an even better price, and delivers for $1 per mile. You ought to contact them for a quote. They have a lot of satisfied customers here on TBN.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
greenworks (A53421)
greenworks (A53421)
BUNDLE OF 25" - 49", 2" X 2" TUBING (A54756)
BUNDLE OF 25" -...
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
UNUSED SDLANCH SDLL30 STAND ON SKID STEER (A54756)
UNUSED SDLANCH...
