Power steering leak
   / Power steering leak #1
ideburger
Member
Batesville, IN
Ford 861
After changing a blown power steering hose last weekend, I now have a leak. Funny thing is, it does not appear to be related to the new hose Although trying to get a good look at the control valve is difficult at best. A quick look at it in the cold tonight and it apoears to be leaking out of something right above the steering housing fill plug. My question is...what is that something?
I see it in the FO-20 manual but it isn't labeled. In figure FO31, it is the piece right under the arrow for the oil seal (part 12). There is a tiny arrow pointing to it, but doesn't say what it is. My guess was a relief valve? Any ideas why this may he leaking?
   / Power steering leak #2
is it the top column seal leaking?
I haven't had a chance to get a closer look yet. It has been too cold! Any idea what the part I described is? It has a cover on it that rotates freely....ie not threaded.
   / Power steering leak #4
how about you actually post a pic... I'm by my manuals about 10 minutes each day.. no more...
Here are some pictures of the piece I am talking about. ..
   / Power steering leak #6
someone with a screen larger than a telephone is gonna have to look at that pic. it jiggles around over my my screen without me being able to see anything usefull.
   / Power steering leak #7
That's the breather/filler vent for the machincal (lower)part of your steering gear.If it's leaking from that,either you have too much gear oil in that part or a hydraulic pressure leak in the control valve caused by a bad seal between the two and is pumping power steering fluid into the lower part.I'll send you some pics via private message. If it's leaking slightly above the vent, it could be a bad O-ring between the two allowing the fluid to leak out.
It is definitely leaking from the breather/filler vent. Replacing that seal looks like quite a job. Any goox adivice? Where can I find the seal?
   / Power steering leak #9
nh dealer maybee?
   / Power steering leak #11
dunno about kit.. but balls and springs, probably
   / Power steering leak #13
Just remembered, Had the same problem with the 4610 SU. Ford's fix for this on the 10 series with AG front axle was running an oil line from the filler plug on the gear box to the return oil line by putting a Tee in the line going to the power steering pump. Just replace the gear oil in the box and the type A tranny fluid in the pump and cylinders with 134 NH ambra or equivalent and let it recirculate in the system. I'm not saying this is the "correct" way to fix it,but just another option.
That would certainly be an easier fix. Any downsides to that? I suppose it would keep the gearbox lubricated.
   / Power steering leak #15
I suppose if the internal leak got bad enough,you could lose some hydraulic pressure in your steering,but I don't think the fluid pressure would be that extreme against a rubber seal as the seal is not a high pressure O-ring anyway. I'd be sure the lower gear case had GOOD seals on the steering arm shafts and caps/adjusters as the 134 is thinner than the 90w gear oil and will run warmer,but there's still no guarantee it won't leak. It did fix the 4610 (as of now) 7 years, but If it was me, I'd go on and fix the seal the right way and be done with it. My 2 cents
Update: I replaced the seal between the control valve and steering gear box and the leak is gone. I went ahead and rewired the tractor while I was at it. Everything wofking great for now except that I noticed my pto seal is leaking. That will be my next project. Thanks again for everyones help.
   / Power steering leak #17
Good deal ideburger. The PTO will be a walk in the park after your accomplishment on the steering. Nice work
   / Power steering leak #18
Resucitating this old thread since it seems I might be having the same, or similar issue with mine. 1954 Ford 600. Just replaced the power steering pump (old one had rusted out internally and seized, and I had disconnected the rams for a year or two to drive it manually -- really fun with a load of dirt or snow in the loader....). Anyway, with the new pump on the there, and fluid flushed and refilled, it now leaks out of what looks like a breather on the steering valve assembly, in the attached photo you can see the fluid oozing down.IMG_1074.JPG It leaks out of here a little if you turn the wheel to either side with the engine off too, not just with it running. Also, the power steering pump rattles when you are not touching the steering wheel, with the engine running, but not if you are turning the wheel. It seems to operate the rams just fine. Ideas? Thanks! Zeke
   / Power steering leak #19
the steering column has seals....
   / Power steering leak #20
That is the breather for the lower box.
Your lower seal in the column is leaking - there is one above and one below the hydraulic block. You will need to pull the tin and steering wheel then disassemble the column to get at it.
Column is not complicated and two seals plus a couple of orings not expensive.
I haven't been around this board for a year or so.
Contact me if you need more help.
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
SWICT 88" SKID STEER BUCKET (A60430)
SWICT 88" SKID...
2017 Ford F-550 (A55973)
2017 Ford F-550...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
