6105 D jd tractor
   / 6105 D jd tractor #11
it came in at 12k unballasted? Or did it have fluid and weights? That sounds like a huge jump from my 5083E!
   / 6105 D jd tractor
the 12k is bare tractor weight no front or tire weights.an no filled rear tires.
   / 6105 D jd tractor #13
Nice heavy tractor. Are you going to fill the rears and hang front weights?
   / 6105 D jd tractor #14
x2. Let us know how that 9x9 trans works out. I have been looking at older tractors since that seems like a bit of a handicap to me?
   / 6105 D jd tractor
no we wont fill the tires or add weights as its heavy enough for what we will do with it.the only added weight will be from the fel if we ever put 1 on it.going to try to take it out sunday an run it some.
   / 6105 D jd tractor
the jd was ran today renovating part of the hay meadow.an you didnt know the renovator was back there.
   / 6105 D jd tractor #17
Hey bull, where did you get the 12k weight at? I just looked at JD's website and it says the 6130D and 6140D are both at 9300lbs roughly unballasted?
   / 6105 D jd tractor #18
My 6125R weighs 12,059 lbs unloaded, I have both rears loaded and I have the loader and it weighs 14,582 lbs.
   / 6105 D jd tractor
the salesmen at our dealer said it weighed 12000.so taking his word for it.
   / 6105 D jd tractor #20
JD 6105D 9390lbs from the website for a 6130D or 6140D no specs on the 105 but i'm assuming it is similiar.
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
RIGID TOOLBOX (A52472)
2011 Crown Victoria Sedan (A51694)
2011 Crown...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
New Long Forks (A53002)
New Long Forks...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
