Iowan
I'd just put tubes in, you could spend the money on slime and then have to put tubes in, slime is a hit or miss thing.
What size are you looking for? Front tire: 15x6.00, Rear tire: 23x8.50 ?I applied a soap solution to the sidewall and air was escaping all over the sidewall. I could hear the air coming through the tire.
A tube will hold air from escaping, but will it help keep the tire in tack for a while longer? If so, I'm thinking that the tube would
help stabilize the shape of the tire better than slime?
Been there with slime on sidewall leaks...doesn't work...and slime is expensive IMHO...spring for an inner tube...yes, it stops leaks and tire will hold together much, much longer than you think it will.
