Wheel chains fit the 3 point arms.
   / Wheel chains fit the 3 point arms. #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
Is it just me or do others have this problem of wheel chains hitting the arms as the wheels rotate? I have R4 tires on the tractor. Some attachments are way worst than others . I like the tiller because it can be adjusted so that there is plenty of clearance where as the winch that hits, rubs and catches every rotation . Once it even broke the chain. Wheel Spacers..... tell me about them. remove tire install spacer, install longer bolts or nuts????
   / Wheel chains fit the 3 point arms. #2
Re: Wheel chains hit the 3 point arms.
Need pictures! Maybe the pins on the winch can be turned in. That would move the lift arms away from the tires.
Do you have check chains or some other sway restrictor?
   / Wheel chains fit the 3 point arms. #4
Yes I do have pins to stop from swing movement. If I had another tab welded on the plow to narrow it , that would also help. Maybe the same thing for the winch.
   / Wheel chains fit the 3 point arms. #6
Try this first. Use 7/8" bolts, at least grade 5.
I have done something similar and it worked.
   / Wheel chains fit the 3 point arms. #7
Can you adjust your tires out one size? Mostly adjusting the
positioning of the center hub to the rim. Your owners manual
should show the positions available.
Good luck :thumbsup:
Tom
   / Wheel chains fit the 3 point arms. #8
If you can't swap the rear tires (side to side) to gain clearance then it looks like you need spacers. I couldn't use chains nor swap the tires to get clearance. I had some 2" spacers made for mine and bought longer bolts. Chains would hit the frame the the ROPS is mounted to. If chains would have cleared my frame they would probably have hit the 3PT arms.
Would rather not go with a bolt . Fabbing a new tab and having it welded on would be much cheaper then a wheel spacer and stronger then a nut and bolt.
Good idea though.
Tom
Manual doesn't say anything about moving the tires out but will have to give the dealer a call.
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2003 McCormick XTX 185 XtraSpeed Tractor (A57024)
2003 McCormick XTX...
