Alternator
   / Alternator
According to the test I have done it seems to be the stator. Shows 0 output.
I have a smsll alternator about 3.5" in dia.
larryd314
   / Alternator
My pto is the electric clutch on the front of my k321 engine.
larryd314
   / Alternator
Well I'm going to side line idea and pull the engine and replace the stator.
laarryd314
   / Alternator #14
larryd314
Did you have the meter on AC volts?
   / Alternator #16
yes set on a/c 100v
Isolate the leads from the stator to the rectumfire/voltage regulator. Set the meter to ohm on the 0-100 scale. Wire to wire on the stator should be 5-20ohm as a rough guess. Set the ohm meter to 0-10,000 and measure engine block to each stator wire. Should read 10,000plus ohms.
Figuring the age of the equipment and hours. She did alright to last that long. On occasion a rectumfire/voltage regulator can short out and that will ruin a stator pronto.
Yes that is what we called rectifiers where I used to work. They were poor design for the particular application and were no end of troubles.
   / Alternator
0 on all accounts, no matter how I check it. I'm pulling the engine in morning.
larryd314
   / Alternator #18
??? 0.0 ohms would be a dead short but most ohm meters show that as something between 0.1 and 1.0 ohms. What does your ohm meter read when the meter leads are touched together ?
In this case a w.a.g. of replacing the stator and voltage regulator/rectumfire often restores the charging function.
   / Alternator
My meter actually reads 1. ZILCH DEAD AIN'T GONNA HAPPEN KAPUT NO WORKIE
   / Alternator #20
I can think of several good reasons for adding an auxiliary alternator. If it's a one wire alternator, it would be a relatively easy thing to do. All that's required is building a bracket to hold it.
I think it's a neat idea, one I will probably do someday.
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
