Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #1
1900freddy
Member
Lorain County Ohio Just west of Cleveland
1900 Ford Compact 4x4
Hi Guys and Gals,
Greetings! New member having a ball trying to figure out why my tranny fluid is dripping between the clutch housing and transmission mating surface on my 1900 Ford. I have owned a Cat D-2 with blade and rear wench and an International 340 with Drott 4x1 loader and Drott ripper. Not totally incompetent to wrench just slow as heck now. My torches still work. Any help with pictures of inside clutch housing to see where a seal might stop leak would be appreciated.
Regards,
David
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #2
Welcome to TBN David. I would post this in the Ford Forum so Sound Guy can help you.
Hi Murph,
Thank you! I am having a hard time trying to search using search function:). I will try to find the Ford Forum on TBN. I have enjoyed reading some of the posts but none were subject specific.
Regards,
David
Hi Murph,
Once again lucky:). I just found a drop down list that came up after my 2nd post and see the Ford/NH forum.
Regards,
Scott
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #5
:welcome:to the tractorbynet.
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #6
Welcome to TractorByNet!
I moved your thread to the Ford/New Holland Owning & Operating forum. :)
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #7
David,
Both rear crankshaft seal and transmission input shaft open i to the bell housing. Are you sure the oil is from transmission. have you given it a smell test. did you check the dipstick both for crankcase and transmission? can you identify the difference. it must be a seal on on or maybe two shafts. The only cure is to split the tractor for further inspection. do you have a inspection hole on the side of bell housing? I have it on my 1700 and by removing the rubber cover can easily inspect the inside with the aid of flash light. Is you clutch slipping due to the oil?
JC,
Ps. Inside of the bell housing for ford 1700 and 1900 are about the same. search clutch replacement in NH owning and operating and you'll get a lot of hits.
Hi JC,
Thank you for the reply. Actually this post is old and since that time I have replaced the clutch. I had no leaks inside bellhousing and have posted pictures in previous posts. My leak actually is being caused by having a leak at the drop box where the front driveshaft meets. The spinning driveshft causes the oil to be slung up to the bellhousing and transmission joint. My problem is how to remove driveshaft and replace the seals and o rings found in the drop box.
Regards,
David
David,
JC,
   / Drippy in Ohio 1900 ford 4x4 Need pictures of inside of bellhousing #9
Oh Okay, so it was external leak. Glad you got it fixed and got a new clutch.
JC,
Hi JC,
Regards,
David
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
