Alternator
   / Alternator
According to the test I have done it seems to be the stator. Shows 0 output.
I have a smsll alternator about 3.5" in dia.
larryd314
   / Alternator
My pto is the electric clutch on the front of my k321 engine.
larryd314
   / Alternator
Well I'm going to side line idea and pull the engine and replace the stator.
laarryd314
   / Alternator #14
larryd314
Did you have the meter on AC volts?
   / Alternator #16
yes set on a/c 100v
Isolate the leads from the stator to the rectumfire/voltage regulator. Set the meter to ohm on the 0-100 scale. Wire to wire on the stator should be 5-20ohm as a rough guess. Set the ohm meter to 0-10,000 and measure engine block to each stator wire. Should read 10,000plus ohms.
Figuring the age of the equipment and hours. She did alright to last that long. On occasion a rectumfire/voltage regulator can short out and that will ruin a stator pronto.
Yes that is what we called rectifiers where I used to work. They were poor design for the particular application and were no end of troubles.
   / Alternator
0 on all accounts, no matter how I check it. I'm pulling the engine in morning.
larryd314
   / Alternator #18
??? 0.0 ohms would be a dead short but most ohm meters show that as something between 0.1 and 1.0 ohms. What does your ohm meter read when the meter leads are touched together ?
In this case a w.a.g. of replacing the stator and voltage regulator/rectumfire often restores the charging function.
   / Alternator
My meter actually reads 1. ZILCH DEAD AIN'T GONNA HAPPEN KAPUT NO WORKIE
   / Alternator #20
I can think of several good reasons for adding an auxiliary alternator. If it's a one wire alternator, it would be a relatively easy thing to do. All that's required is building a bracket to hold it.
I think it's a neat idea, one I will probably do someday.
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
