motownbrowne
Elite Member
- Joined
- Dec 30, 2013
- Messages
- 2,612
- Location
- river falls, wi
- Tractor
- Kubota mx4700 HST, New Holland TC-29D
That's a technique, though not a tool, that I use every time I split wood. I use a gransfors bruks splitting maul, which I LOVE, I learned about "splitting with a twist" from peter video, a renowned scythe advocate from Canada. He's right about it being easy to do with any axe or a sharp maul that will penetrate a round. I use the technique in conjunction with a bungee cord around the round. First I stand up the round, put the bungee around it, then spilt the sides off all the way around. Then I split the sides into small pieces (our evaporator likes small wood). I use the twist method to split the sides which are on the opposite side from where I'm standing because it protects the handle. All I do is hold the bit at a slight angle while still swinging straight down. The weight of the head levers the pieces apart. Takes some getting used to, but it's a great tool to have. The bungee method holds all the pieces together, and really makes the task a joy.
Axe Connected: Wood Splitting with the Twist
