CalG
Super Member
- Joined
 - Sep 29, 2011
- Messages
 - 9,012
- Location
 - vermont
- Tractor
 - Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
You're right, it does suck more air than wood....now I am thinking about a small blower & drip the oil into a cast iron pot with something small in the center of the pot to make the drop splatter. I think I can make it better if I give it more O2.
That will work! It will pulse with each drop as it hits the fry pan, but there will be lots of heat. I've seen one set up just that way. About a drop every two seconds is what I saw. Whoo.... Whooo
The blower fan was in the door, with a small drilling in the stove top above , just in about 8-10 inches (this was a long narrow stove, not wide and shallow like yours) with a fitting to connect the gravity oil feed pipe. The fan ran constantly (must have really burned the wood!)
A cast iron fry pan from the harware or second hand store is just the ticket. set it up on wiers or weld in some cross bars so you can get wood or coal under it. Once it get's hot, it takes care of it's self. No wood needed. Don't worry about the splash, the pan get so hot, that the oil vaporization sends the liquid oil out in a real scatter.
I'm not sure how to keep the drip feed inside the stove from coking up. It would seem that the oil feed should be shrouded with fresh air to reduce temperatures. That would be a good design exercise.
