Smartphone Photo of the Day
   / Smartphone Photo of the Day #311
   / Smartphone Photo of the Day #312
Tell me why I live here again?
WP_20140205_001.jpgWP_20140205_002.jpgWP_20140205_003.jpgWP_20140205_004.jpgWP_20140205_005.jpg
   / Smartphone Photo of the Day #313
Because you love to play in the snow! :D :thumbsup:
I don't like to play in the snow, that is why I moved from Indiana to Oklahoma, in 1966.
This is our biggest snow fall this winter.
   / Smartphone Photo of the Day #314
No... dont like it... Not at all :)
   / Smartphone Photo of the Day #316
Meanwhile in the deep south!
   / Smartphone Photo of the Day #317
I don't know how well these are going to show up. With the new snow here today things are pretty washed out. In the 1st you should notice several robins (there were at least 30 birds in this tree at times) sitting in our Japanese lilac tree waiting for their turn at lunch. IMG_20140213_104719_857.jpg In the second you might find one of the lucky robins in the holly bush apparently lunching on the berries.IMG_20140213_104917_583.jpg
Remember, spring will be here soon!
Frank
   / Smartphone Photo of the Day #318
Below are a couple of shots I took while pulling this Cummins 6CTA 8.3L 450HP engine out of a 48' Novatech yacht. The engine got salt water into the cylinders and seized it so we need to put a new one in.
The problem is that the boat builders didn't leave any openings large enough to get the engines out (typical for short-sighted boat builders). I had to remove a window, which is the largest opening in the boat, but is still only 28" high. The engine is 45" high. After removing the cylinder head, most of the components, and the oil pan...the engine just barely fits if it's chained to a long forklift fork...there is about 1/2" vertical clearance coming out the window.
First photo is the engine removed from the engine room and set on a pallet and blocks in the salon. Engine is normally 1500 lbs but stripped down like this it's probably around 900 or 1000 lbs. The second photo shows the the rigging to remove it through the window. I wanted to get a shot going through the window, but I was so worried the fork may bend that I didn't want to waste any time.
I've pulled many engines from boats but this was one was not fun at all. And the sad part is that I need to strip a brand new engine down to get it in the boat and then reassemble it once in place. Stupid boats.
Photos taken with a Samsung Galaxy S4
   / Smartphone Photo of the Day #319
Sunset at the Larro Ranchero
   / Smartphone Photo of the Day #320
View outside my studio window this morning.
*Cheat - camera, not smartphone. :eek:
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2009 Dodge Ram Utility Pickup Truck, VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
