the grade 8 bolts where stronger than the steel!
   / the grade 8 bolts where stronger than the steel! #11
You didn't say but it looks like you've attached a
snowplow to a SSQA plate.
Why bolt to the QA adapter plate? Why not weld?
As has been said the tubing was undersized for the
application, and putting down pressure on there as
you said significantly increased the loading on those
undersized parts.
   / the grade 8 bolts where stronger than the steel! #12
The bolt holes through the most highly loaded (farthest fibers, on either side) of the section and the direction of loading make for a "tear here" stress riser. I'd wager the bolt holes weren't deburred after drilling, either.
The connection design needs to be beefed up and reconfigured, and it sounds like the OP is aware of this.
Personally, I'd prefer to see some angle iron "wings" welded to the box section with bolt holes thru the angle iron "tabs" as anchoring points.
Or weld a section of flat stock to the bottom of the box, between the box section and the thing you're bolting it to. Drill bolt holes in the flat stock and you remove stress risers from the box section itself.
   / the grade 8 bolts where stronger than the steel! #13
:thumbsup: Thank you for your [correct] assessment and good design points.
larry
   / the grade 8 bolts where stronger than the steel! #14
Thanks for the kind words, Larry!
   / the grade 8 bolts where stronger than the steel! #15
I particularly liked the mention of deburring the holes. Few realize the importance of eliminating sharp edges. Fewer think to extrapolate to the holes used in fastening. ... both sides. A deburred machine is stronger, lasts longer, and you dont bleed as much.
larry
Well so many comments..where to start?
No I do not teach my students to build like this- its what I had in the barn.
"What a rusty piece" - well lets see, its cold here, been cold since Oct- when I built it, do you paint in freezing weather?
Undersized steel, well I'll agree, but its what I had, and it did work till we got that last 18" dumped on us, it failed from my actions. I have bent the tubing for a previous project and it took 4 tons to bend it in the press on the 1" side, so it would hold but I did it in with the down pressure.
Yep my TC40 weighs in at just under #7K, every other weekend I drive up the road 1/4 mile to get coal. With the trailer it weighs in @ 7,234 pounds, the trailer weighs 621 pounds empty. The backs are FULL of rim guard.
I got the 3" channel tonight, 1 1/2" Height and #5 per foot- for those who want the specs. I am eliminating all the tubing with the channel. But still no paint till spring, and its going to be IH red, when I paint my old wagon the plow mount will get the loft overs.
   / the grade 8 bolts where stronger than the steel! #17
It was not "what a rusty piece" but instead "What is the rusty piece" I wasn't sure what I was looking at whether it was a QA plate or something else. I was trying to understand how it all went together,,,that's why I asked for better pic's.
   / the grade 8 bolts where stronger than the steel! #19
I always deburr any hole I drill, but I thought I was just being ****!
What's the importance of it structurally?
   / the grade 8 bolts where stronger than the steel! #20
Anything with a sharp aspect essentially "sits proud" with lots of material on the structure side - then nothing at the point. When the structure moves/flexes all the non sharp parts have material right beside them to share stress. That part of the structure, perhaps right next to a sharp edge, flexes harmlessly; elastically. - - But that sharp edge sits further out [or in] and must stretch or compress more than neighboring smooth material it is part of. And the edge has no neighbor outboard or next door to share the load. Its deformation is much more likely to be plastic. Enuf and it starts to tear. Less, and repeating reversals just work it back and forth enuf times and it cracks and tears anyway. All the smooth material around is now prying on the sharp root of that crack - and that crack is eating its way into the smooth parts. ... And so on.
larry
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
