Tractor Sizing workmaster 55 for landscaping work
   / workmaster 55 for landscaping work #1
italianstallion69
PA
Kubota L2250
Hi,
I own a 1993 kubota l2250 we use for commercial landscaping. Mulching, raking with drag harrow, moving 300-400# trees, moving pallets of plants. using a PTO auger to drill holes.
I am looking at adding a 2nd larger newer tractor , looking at workmaster 55 and mahindra 4010.
I need a larger tractor to move pallets or rolls of sod which can be 2000# -2500#.
Does anyone here use/have used a workmaster 55 with a
FEL danuser ep6 hydraulic auger 12-24" bits for shrubs and trees?
bobcat rockhound 5b landscape rake (1100# empty)
How well did it run with the 11 gpm flow? the minimum on both equipment is 6 but I have only run them on bobcats which are 15+gpm.
The downside of the mahindra is less gpm albeit a cheaper price. ony 8 gpm vs 11.
The downside of the workmaster seems to be low curb weight at 4,000# probably need a heavy counterweight with it.
I have not seen the workmaster in person only specs it is 2 feet longer than the kubota but 28 rear tires vs 24 so I think a bit higher up. We usualy have fairly large space on commercial sites to manuever but I dont want a tractor too big for the job.
Thanks!
   / workmaster 55 for landscaping work #2
Hi,
Thanks!
Maybe you should look at the Mahindra 5035. A bit closer to the 55 Workmaster. Actually sit on the 5035, just be prepared to make the purchase if you do.:rolleyes: They are a pretty nice machine. ;) Around 6500lbs with the loader. Easy to ballast and get close to 8000lbs if that is what you want-need.
Adams 6 Ton Hydraulic Lime Spreader (A57024)
Adams 6 Ton...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
