Boomer says, Brrrrr it is cold out
   / Boomer says, Brrrrr it is cold out #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
I have owned my TC29D now for ten years. In the summer it sits outside in a shaded area so I don't fade the paint. Every winter it gas been in a heated garage. Well the garage for some reason has shrunk and now I think Boomer has no choice but sit outside for a while. I have unraveled the block heater cord as I have never used it and now can plug it in a couple hours ahead of time. It will be interesting to see how well she starts in this subzero cold weather we are having.
Or should I just leave it plugged in all the time, is 2 to 3 hours enough time?
   / Boomer says, Brrrrr it is cold out #2
Hiya Murph,
I've heard 2-3 hours would be plenty. My little TC18 doesn't have a block heater, but so far it's started every time I needed it to so far this season with just the glow plugs. Our weather has been somewhat similar to yours, except you've been a bit colder.
Jerry
   / Boomer says, Brrrrr it is cold out #3
You might see some fuel issues show up like ice and gelling. You may want to treat the fuel to prevent that, a block heater will not.
   / Boomer says, Brrrrr it is cold out #4
My TC33D sits in a non-heated pole barn. Down to about 15 degrees, it starts fine. Below that, I usually plug in the block heater and have never had a problem after 30 to 40 minutes. After that, it is a 20 minute warm up with both pto's running and a bit of pedal with the cruise on and the speed range in neutral. I also suggest covering the transmission cooler. I use 5-40 weight synthetic oil year round, which helps a lot this time of year.
   / Boomer says, Brrrrr it is cold out #5
Run the extension cord through the steering wheel, so you don't accidentally drive off and cause more damage than you want to try to fix in the cold.
That I do even though it sits in the garage.
:) well that is probably something I would do too. Thanks for the tip.
It is sitting about -10F right now headed for -15F tonight. One thing about it being this cold I won't be getting much snow.
Hiya Murph, I've heard 2-3 hours would be plenty. My little TC18 doesn't have a block heater, but so far it's started every time I needed it to so far this season with just the glow plugs. Our weather has been somewhat similar to yours, except you've been a bit colder. Jerry
Hey Jerry, how are you doing? I think the whole States has gotten some pretty cold weather. On the news tonight our frost even with all the snow is a foot deeper than all of last year. Traveling a lot in the Minneapolis St Paul area and it is not uncommon to see broken water lines in the streets.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2008 FORD F-350 (A52472)
2008 FORD F-350...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2013 F-550 Bucket Truck (A52748)
2013 F-550 Bucket...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
