BX2660 shut down, will not start
   / BX2660 shut down, will not start #11
Make sure you push the PTO lever off FIRMLY. There is a little micro switch in there that can be really finicky if the lever isnt firmly bottomed out.
Also double check the F/R pedal. Make sure its centred. There is the possibility that the switch itself is broken or jammed in some way.
I think your issue is in the safety switch system some where.
Nope. No luck. No combination of maneuvering the PTO, for/rev, neutral/hi/low, 4WD or 2WD makes any difference.
Lights come on fine. Glow light indicator lights up, fuel pump clicks, but absolutely nothing happens when turning key farther to start. The engine doesn't "cough", or make any sounds like its even trying to start.
Is it possible the fuel gelled after being in sub-20-degree weather for several hours?
Work schedule prevents me working on tractor for a while, but I will check the fuses at first opportunity. Other than that, my suspicion would be the kill switch in the seat, since it died just after I got off the tractor. But my experience with all things mechanical is almost nil, so I'm just guessing based on what I have read in some other threads.
   / BX2660 shut down, will not start #13
Its not gelled fuel. Then it would crank and crank but not start (been there, done that). You can start out BX2660 without being in the seat, so its not the seat switch. It has to be the PTO switch, the fwd/rev switch, a fuse or a loose wire somewhere.
Aaron Z
   / BX2660 shut down, will not start #15
I had that problem with my BX. It was the seat safety, jumped up and down on the seat and it worked again. 3rd time I went a lookin'. Found the bracket for the switch was bent down, straightened it back up and works fine now 200 Hrs later.
Ron
   / BX2660 shut down, will not start #16
lift the seat up and leave it up. If holding the pto lever back in off position doesnt work while attempting to crank engine, then check the wiring for pto. the bracket. try holding the button in with your finger instead and wiggle it. if it still fails, get underneath tractor and look at your HST switch. hold it in with your finger and attempt to crank it. you should be able to barely reach for key while holding switch in if you are 5 foot or taller. no need to get it started, but be able to diagnose it by getting it to crank. Did you check the while starter wire connector to make sure its all tight?
You should be able to find the problem as the BX starting safeties is pretty simple.
OK. Finally got a chance to look at the tractor. I loaded up my tools and drove to the end of the road. Figuring I had nothing to lose, I sat down on the seat and turned the key. It started right up like nothing was ever wrong. Mind you, I touched nothing, I just put my rear on the seat and started her up. I got back off and let it warm up for about ten minutes, then got back on.
Frustrated by the previous issues, but smiling because she's working again, I drive the tractor back up the road. I get to the garage and put on the parking brake. Then I hop off to start the air compressor because the front tire is low, and the tractor immediately cuts off. And it will not start again.:hissyfit:
My guess is its gotta be the seat kill switch.
Going to walk back up the road - again - and get the truck. If you guys think of anything else, please let me know.
Lost
   / BX2660 shut down, will not start #18
Bypass the seat switch and be done with it.
I got underneath the tractor and believe I've found the culprits. The seat switch seems fine, but some branches had worked their way up by the HST fan and looks like they were holding a contact switch next to the fan open enough to prevent a good contact.
In the first pic, you can see the largest stick on the left. Just behind the stick is a spring running straight up to the curved, not quite L-shaped, metal arm that connects to the white plastic encased contact in the center of the fourth pic.
The second pic is another view of the spring which is attached to a bolt. That bolt, when under tension of the spring, holds up another metal arm.
The third pic shows the culprits I removed next to a hammer for size comparison.
I've since been able to get on and off and start and stop the machine with not trouble. :cool2:
   / BX2660 shut down, will not start #20
Congrats on figuring it out. It is just really really frustrating when you have a machine to help do rough, hard work and problems occur because some sticks interfere with all the foolish safety garbage our government requires. Just frustrating. Plus, we have to pay for all that stuff. Rant over.
MoKelly
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2017 Jacobsen Greens King IV Plus 62in Reel Commercial Mower (A56857)
2017 Jacobsen...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A58375)
2013 CHEVROLET...
1992 VIM TRAILER MFG CRUDE TRAILER (A58214)
1992 VIM TRAILER...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
