42 or 48 inch pallet forks
   / 42 or 48 inch pallet forks #1
corl
West Grove, Pa
2013 Kubota MX5100 HST, 1989 Kubota F2100
I have an MX5100 HST Kubota and am contemplating buying pallet forks. I can see a lot of uses for them but don't know enough to make a decision. Prices are all over the board and I have no idea if I should get 42 inch or 48 inch blades. Dealer has suggested 48 inch. I have rigged the tractor so I can stand up while working without the engine dying so I will not have trouble seeing the blades no matter what length I choose. What criteria should I use to make the choice? Thanks for the help!
Will probably be moving wood and brush, tree limbs etc and lifting some pallets
   / 42 or 48 inch pallet forks #2
48" will stick out the back of most pallets. You'll be happy with either. 48"s if your doing mostly brush and wood, 42"s if you're doing mostly pallets. Let us know what you choose.
   / 42 or 48 inch pallet forks #3
I got clamp-on 42" (from Palletforks.com) for my M4700 and have moved a lot of brush with them.
And a number of pallets.
Well worth the $240.
   / 42 or 48 inch pallet forks #4
Advantages of going small - lighter, cheaper, maneuverable in tight quarters
Go big - fit more material, easier to lift pallets out of pickup trucks/position pallets on trailers, easier to see, lift 5.5x5.5' deer blinds, room to quarter 5 hogs, etc
I kinda wish I went 60 vs my 48 but never heard if anyone wishing they went shorter...
   / 42 or 48 inch pallet forks #5
48" on my MX5100. I used them a good bit for brush until I bought a grapple. Much more efficient for many things.
   / 42 or 48 inch pallet forks #6
Went through same decision. Went 48". No regrets. As someone posted, might would like the 60".
   / 42 or 48 inch pallet forks #7
I would suggest you look at WILDKAT ATTACHMENTS by Mid-State Equipment Buckets, Grapples, mowers, augers, and more for your Bobcat, John Deere, and others! , They have 48" forks for $600. I bought a set a couple of years ago, and have been very happy with them.
I don't think 42" offer any advantages that would make me choose them over a 48".
The weight of the forks may be a factor. The more they weigh, the less you can pick up.
I had a set that I built from a salvaged forklift. They worked OK but were real HEAVY:eek:
Good luck, Bill
   / 42 or 48 inch pallet forks #8
Good luck, Bill
I have the same set from Wildkat. Yes, it has worked well. Not too heavy which keeps reasonable lifting capacity and it's rated capacity is well above my tractor lift capacity. I welded some steel tie-down points to both sides so that large items can be efficiently strapped on the forks for safety.
Btw, Wildkat has given me a little better deal than the web price when I show up in person to buy. I believe I bought mine for $500 about 2 years ago-but I'm only 40 miles from them. While you are at it - you may as well look at their grapples. They have good prices on those too. I was just using mine on Monday to clean out some brush to extend my driveway. What a back saver!
HP
   / 42 or 48 inch pallet forks #10
I bought 42 since they were rated at 2000 lbs My FEL will just lift 2000lbs so didnt see the need for 3500lb forks.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
1270 (A50490)
1270 (A50490)
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
Unused Delta Crash...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
