MF 35 Plugs
   / MF 35 Plugs #1
Bigwoods
Northern Minnesota
135 Massey Ferguson
Hello. I am new and learning a lot. I have a 1967 MF35 with a Perkins 3 cyl. I just replaced the coil but replacing the spark plug look kinda awkward. Is there an easy way to get at them? Thanks.. I'm sure i'll have more questions.
   / MF 35 Plugs #2
Hey, Perkins only made Diesel engines to my knowledge and continental made the gasoline engines for Massey ferguson. We have a t0-20 and a Ferguson 40. Both I believe have continental gasoline engines
   / MF 35 Plugs #3
Perkins makes both diesel and gas engines. Perkins Engines
   / MF 35 Plugs
I should have said a MF 135 Deluxe. I looked at it again and found a cracked plug wire so I want to replace the wires and the plugs. The only way I can figure out how to do it is to remove the fuel tank.. Of course it full so that should be fun. If I could just get the wires I would wait till it warms up to do the plugs.
   / MF 35 Plugs #5
I was curious as to why a gas Perkins would need to have the tank removed to install plugs and wires. Now on a 135 it looks pretty straight forward. Can you not use a knuckle on a socket extension to get to them. My Honda plugs are harder to get to then on that gas Perkins.
   / MF 35 Plugs #6
Perkins plugs can be removed without taking the tin or tank off. There is a small heat shield that comes off easily to give you better access.
   / MF 35 Plugs #7
My recollection is that the first gas 35 type tractors (TO35) in the US were Continental, then there was a period of 3-cyl Perkins gas being used on MF's and then a switch back to Continental until when they didn't offer gas anymore. I think a dealer told me that the Continental gas was a little more fuel efficient than the Perkins gas. The only gas ones I have operated were Continental 4-cyl.
   / MF 35 Plugs
Just to follow up. The weather got into the 30's and it was a lot easier to work on the 135. I removed the heat shield and the metal body work with 4 screws. I replaced the plugs, wires, coils condenser and points. I had cleaned the sediment bowl and went a head and replaced the gasket. It fired up the first try.. Thanks for all the help. I will keep reading and learning.
2023 Kubota SVL97-2 (A50123)
2023 Kubota...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A53426)
2023 EAST TEXAS...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
CONTACT INFO (A53084)
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2012 Talbert Lowboy T(4)-55SA-BC-HBG (A52384)
2012 Talbert...
