hunterridgefarm
- Joined
- Jul 12, 2005
- Messages
- 2,131
- Location
- Western NC
- Tractor
- Kubota L3130DT, Kubota L185DT, JD LX277
I inherited my Grandfathers woodworking equipment years ago. This equipment is 45 years old and HEAVY cast iron and thick metal. I swear the table top drill press has to weigh close to 150 + lbs or it at least felt like it when I carried it from the back of the truck to the basement
I had stored it at my dads for the last 15 years in his workshop, when he was diagnosed with Alzheimer's and before he passed, I was worried about him hurting himself so I cut the plugs off the equipment. There also was some dry-rot on the wire with exposed wiring.
I am now moving the equipment to my house and plan to rewire all of it as the insulation just crumbles when moving the wires.
I currently have the drill press and bandsaw at the house. The drill press has a switch on it that I feel sure my grandfather added as I cannot find one on line with a switch. The picture show the switch and motor.
Any suggestions on type of wiring to use and would you keep the switch on the press? Most of his equipment has no switches, you just plug them in.
I still have the tablesaw, joiner, shaper, sander, planer, radial arm saw, to move and rewire. Plus lots of clamps and tools to move. Only problem here is finding it all. When dad had Alzheimer's he had a tendency to hide things so finding it all will take some time.
We have finally made a decision on the workshop and hopefully in the next 2 months we will have it up. Just needs to dry out a little and I have 10 more pines to take down that will pose a risk of falling on the shop once it is built.
I can't make any post over the weekend but may be able to read reply's.
David
This thread will require the use of the tractor to unload the larger equipment, Just need to figure out how to load it in the back of the truck
. My trailer is too long to make the turn into the driveway. Long one lane drive with several houses.
David
