generator whole house transfer switch
   / generator whole house transfer switch #31
Ah, but do they give themselves Millions in bonuses? This province and Country is run by Criminals who happen to make the rules! Handy how that works, (for them)!
   / generator whole house transfer switch #32
....they make them for just about every modern panel out there. You simply install between main breaker and the generator feed breaker. After you turn off the main, the generator breaker becomes available to operate....
Problem is, if you have a 26 yr old box I wonder if they do indeed make one that will work. I have an old skinny 200a Westinghouse panel and instead of the main breaker being at the top of the panel(like I'm use to seeing), it's the first dual-set of breakers on the left buss-bar. Or at least that's what it looks like without the cover off. Sure would hate to have to replace my entire panel just to accommodate one of these, but they seem to be the economical solution, along with a simple small sub-panel, or receptacle box. I've got to select a solution and quickly before the next outage.
Yesterday, my kids and I were home due to storm PAX and at 3:25 we heard an explosion and our power died. I immediately called the utility co. and reported it(luckily I was able to get to a live person). Long story short... a snow plow up and around on another culdesac plowed right into a transfomer and boom! Not sure what happened to the driver if anything (hopefully not). So while it wasn't a downed power line due to the freezing rain, it was still weather related. I feel like I dodged a bullet this time. Hence the interest in this topic now. Power was restored about 3 hours later.
   / generator whole house transfer switch #33
how about this one. look at the westinghouse...last one on page
Generator InterLock Kit - Westinghouse Manual Transfer Switch Kits
http://www.interlockkit.com/InstrK9010NewDsn.pdf
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
