Hot Tub Heating Alternatives
   / Hot Tub Heating Alternatives #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I think I already know the answer.
Someone gave me a free hot tub a few years ago. I heat mostly electrically at .15 CDN/KWH, no time restrictions. I disconnected the hot tub element, not wanting to add to my electic bill. The first year, I used loops of black pipe as a solar heater, which worked well except for the unsightly mess and limited heating window, then built a wood fired boiler that was a lot of work to keep going and wasn't very efficient, plus the smoke blew right in the windows of the house!.
I was considering getting a used oil fired hot water tank and running it on Diesel. But in addition to the expense of the tank and the hassle of putting yet another thing to bed in the winter, would this cost more then just using the electric element? Diesel is about $1.30 CDN/litre.
Thanks
   / Hot Tub Heating Alternatives #2
Try solar panels. If you can do it DIY it will cost about $2.3/W of installed rated power before subsides or rebates (if you have such a thing in Canada.) What would you do next depends on the type of contract with the utility. In example if you have net metering you don't need to anything. If the sale price is lower than buy price then you can heat the tub only when there is power from the PV available. In example you can use a timer and turn the heater on only when there is satistical probability that the PV generates power. Or you can isnstall a solar power diverter that will send such amount of power to the heater so you will not export any.
Interesting Point. Rather then frick around with insulated piping and having to drain the system in the winter, solar panels would be better. No inverter required. Just hook them up to the heating element. Actually, that might be hard to get 240 volts DC! A lot of panels. I just don't like inverters, even though I can get them for free from a friend!
Watt for Watt, on a small system, what is the difference in cost outlay between hot water solar heating and PV Solar? I thought about it, but am not sure I am up to building a hot water solar array.
   / Hot Tub Heating Alternatives #4
Do you want to use it in the winter, or are you just trying to keep it from freezing? If you're just trying to keep it from freezing, toss some (non-toxic) antifreeze in there. Drain/refill it when you're ready to use it in the spring/summer.
Keith
I built a substantial steel frame for it with fork pockets. I put it away in the winter. I have a hard enough time on cool nights making it back alive to the house. Although I imagine the experience of using a hot tub in the winter to be quite enjoyable, I don't know how I would ever find the courage to get out!
   / Hot Tub Heating Alternatives #6
Have you got an idea how much electricity it actually uses? I ask because I have a fairly new hot tub and it uses very little power. I don't really notice it. The company that installed it estimated it would not be over $10 a month in the dead of winter.
I keep hearing things like that. I know the heater isn't on all the time, although in the dead of winter, who knows. But, just sayin, if it were a 2000 watt heater, on for 30 days at .15 KWH, that would be $216.00! If it was on a quarter of that time, it would still be $50.00! And that is not accounting for use, with the top open. Thinking about it, I can't imagine even running the circulating pump for ten bucks a month!
I just remembered I had the pack next door here. I looked. The heater is 23 amps at 220/240! That's five and a half thousand watts!. Not that it means the thing uses any more energy at the end of the day.
I think the hot tub people are blowing smoke up your . . .
At ten bucks a month, AND in the coldest time of year, I would have to be a complete Idiot to mess around with my solar piping and wood fired boiler or buying and installing PV panels!
It would sure be nice though.
EDIT: I just did some more calculations. A 100 watt Edison bulb (remember those?) left on continuously would cost a little more then ten bucks a month at .15 KWH.
   / Hot Tub Heating Alternatives #8
I wish I knew exactly what it uses but I'm always amazed at how little electricity I use. I get close to but never exceed $200 in the winter (pool pump runs it a little higher in the summer).I know that sounds like a lot to some but I have a large house. I have two baths with heated floors. I run an electric space heater in a three seasons room. The usual appliances- an electric dryer, etc.
When the hot tub is not in use the pump only runs a few times a day for a few minutes. We have not used it for a month or so because of the snow. It's just melting now because I lost the battle trying to keep it clear. It does not lose enough heat through the cover to melt snow.
   / Hot Tub Heating Alternatives #9
Typical 250W panel will produce about 30VDC at about 8.4A under load. If you want to avoid inverter then divide the rated voltage of the element by 30 to get the number of panels. Then multiply number of panels by the panel rated power to get the wattage of the heating element. You can use smaller element but then the voltage from the panels would be higher. I would still recommend using inverter. It could provide power for your house when the heating element is off.
Panels are in in average 80 cents (USA)/W. 2kW inverter is about $500 USD. If you would use the panels only for the hot tub then you need inverter that can operate in "island" mode. You can get one with modified sine wave. Those are cheaper and the element doesn't care what the sine wave is.
I would guess you need 6 panels and 1.5kW inverter plus something to mount the panels on and wiring. All for about 2000-2500 USD.
The beauty of PV is that it is virtually maintenance free.
   / Hot Tub Heating Alternatives #10
I just keep mine turned on and pay the bill.
If its not worth the dollar a day to keep it on why bother,drain it for the winter.
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
