Briefly running engine in garage
   / Briefly running engine in garage #51
CO exposure is cumulative, which is why firefighters need the reduced exposure levels. Think of asbestos. It was used everywhere, in vermiculite, floor tiles, roofing shingles, brake pads, etc. Lawsuits put many companies out of business AFTER the dangers were discovered, and the suits continue today. It wasn't thought of as dangerous until it was found out to be, and then it became unsafe to handle, to be exposed to, without proper handling methods, (which are extensive, and performed only by licensed and highly trained abatement companies).
Mowers and tractors, both gas and diesel do produce CO. Could an operator get seriously sick or die from exposure to CO from a riding mower, zero turn, tractor, mini-ex, etc.? Possibly, probably and maybe. Just because one can't locate statistics documenting something doesn't mean it can't / doesn't happen.
I can attest to getting headaches from mowing on 'still air' days, and on days where the exhaust is around me. Same with my diesel tractor. BTW, I use a zero turn, and used to use a conventional under cowl mounted ride mower and have had wicked headaches after using either. When mowing, one is usually exposed to CO that lingers in the air as you come back around the last cut area in an overlapping cut pattern, regardless of what type of mower one uses. If one really wants to reduce/eliminate CO exposure from cutting one's lawn I would hire out the job to a lawn care company. Seriously, that's about the only way to limit exposure significantly.
And joking about how 'funny' it seems to take CO exposure seriously is just plain stupid.
People die everyday in their own homes as a result of exposure to CO, and regardless of cause or reason why, that in an of itself is a seriously sad commentary on a completely tragic and totally preventable outcome. Ignorance and lack of knowledge about proper prevention, including and beyond detection meters and alarms is still a major factor in home deaths and poisoning from CO.
No one should suffer the damage of CO poisoning, long term exposure or death.
Knowingly risking exposure to an odorless, tasteless, colorless deadly poison is complete foolishness. One doesn't need testimony from some self proclaimed expert in the field of exposure to deadly toxins to conclude that the dangers are real, though the exposure levels may vary significantly from site specific conditions regarding one's lawn cutting tasks.
   / Briefly running engine in garage #52
Information has been shared. Everyone can use it, or not, as they see fit. Insulting those who disagree with you violates TBN rules.
   / Briefly running engine in garage #53
Agree with mikepa. TBN is blessedly free from the insulting posts that diminish so many other forums.
   / Briefly running engine in garage #54
Hi Mike... I guess I missed the 'insult' in my reading and following of this thread. While I definitely agree that this is a serious topic and we can learn from many of the comments here, I don't see anything wrong with a little levity as long as it is not a personal attack. If we didn't joke and laugh a little, it would be a pretty boring place in my mind.
   / Briefly running engine in garage #55
OutBack,
I don't think you really have anything to worry about outside because its out on the fresh air. The only time you should worry about co levels is in an inclosed area where the fumes can take over.
Adam
   / Briefly running engine in garage #56
This topic is not nearly as serious as some here make it out to be. It's worth laughing at, IYAM.
   / Briefly running engine in garage #57
What he said!! You can not go through life being afraid of you own shadow... With these kinds of comments in a few years you will only be able to buy an all electric tractor?? But then you would have to worry about the acid from the batteries leaking of not using it in wet weather do to electrocution...
   / Briefly running engine in garage #58
No, no... don't say it. An electric tractor! :thumbdown: There is something about the sound of a diesel in the morning! :thumbsup:
   / Briefly running engine in garage #59
And the smell of Napalm.
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
49205 (A55788)
49205 (A55788)
10 ft Shipping Container (A55973)
10 ft Shipping...
2016 Bobcat E85 Midi Excavator (A55851)
2016 Bobcat E85...
2023 KUBOTA SVL75-2 SKID STEER (A52707)
2023 KUBOTA...
USED 3500 LB TRAILER AXLE W/ BRAKES (A57192)
USED 3500 LB...
