Good landscape rake - cheap (Part 2 - Daver1963's attempt)
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #1
Daver1963
Idlewild, Tn
Kubota L2800DT w/LA524 FEL, Cub Cadet XT1
Back in December I saw this thread Good landscape rake - cheap. To summarize, if you don't want to read this thread, member RedDirt built a landscape rake from hay rake replacement teeth, a piece of pipe, and some angle iron. I decided I could do something similar and attach it to my King Kutter carry-all. Here are the results:
1) 01 Rake on sawhorses.jpg 2) 02 Closeup of hay rake teeth.jpg 3) 03 Tractor with carry-all.jpg 4) 04 Tractor with carry-all & rake - side view.jpg 5) 05 Tractor with carry-all & rake - back view.jpg 6) 06 Tractor with carry-all & rake - back view close up.jpg 7) 07 Tractor with carry-all & rake - back view even closer up.jpg
Pictures:
1. Yard rake on saw horses
2. Close-up of the rake teeth and clamp
3. Tractor with Carry-all on.
4. Tractor with rake - side view
5. Tractor with rake - back view
6. View of clamps on Carry-all
7. Closer view of clamp.
Parts:
1. Rake teeth 15@ $1.99 each
Herschel Adams Universal Rubber Rake Teeth T16-0182 by Herschel Adams for $1.99 : Rural King
2. Steelworks 4-ft x 1-1/4-in Plated Steel Perforated Angle 1@ $14.08 08 Angle Iron part number Sticker.jpg
Cut into: 2 - 5 inch; 2 - 19 inch
Shop Steelworks 4-ft x 1-1/4-in Plated Steel Perforated Angle at Lowes.com
3. Steelworks 3-ft L x 1-1/4-in W x 1-1/4-in H Plated Steel Perforated Square Tube 2 @ $17.24 09 Square tube part number sticker.jpg
Shop Steelworks 3-ft L x 1-1/4-in W x 1-1/4-in H Plated Steel Perforated Square Tube at Lowes.com
4. 5/16 bolts, 2ス" long, qty: 15
5. 5/16 bolts, 5ス" long, qty: 4
6. 5/16 bolts, 2" long, qty: 4
7. 5/16 nuts, qty: 23
8. 5/16 lock washers, qty: 30 or so
9. 5/16 flat washers, qty: 60 or so
10. 5/16 fender washers, qty: 4
Construction:
1. The two 19 pieces of angle were used to hold the two square tubes together. Four 5/16" - 2" bolts were used to connect the pieces. I had to adjust these as I put the teeth on.
2. The hay rake teeth were spaced every 5 holes on the square tubes. The spacing of the holes on the tubes and angle iron were 1 so that the teeth are space at 5 intervals. The hay rake teeth also have a slight dogleg bend at the bottom and I made sure they all faced the same direction. The flat washers and lock washers were used to take up some space between the bar and hay rake teeth as needed. Except for tines that were on both the angle and square tube every other tine was double lock washered and used 4 flat washers.
3. The 2 pieces of angle iron cut 5" long, the 5/16 bolts - 5"?ス?ス long, 4 fender washers, 2 lock washers, 2 5/16 nuts were used to make clamps to hold to the King Kutter Carry-all. The clamps were spaced to fit the carry-all.
4. The rake was connected to the Carry-all with the dogleg of the tines facing inwards toward the tractor.
Performance:
I determined how low I wanted it to go and set the stopper on my draft control to that. To try it out I used it on some pine needles that were on a slope. Results:
1. The rake was pulling the pine needles along, but it was also digging into the ground. I'm going to try flipping the rake 180?ー so that the dogleg of the tines faces away from the tractor.
2. After the tines had raked all the needles it could rake I needed to lift the tines out of the pile, but the Carry-all would not raise it high enough. This is just due to the dimensions of the Carry-all. To fix this I'm going to have fabricate a 3 point hitch that will allow me to lift it higher. I will post pictures of that when I get it done. The plan is to use angle iron.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #2
Hmmm... cheap, for sure, and clever construction method. Just try to never hit a rock, or root, or anything frozen, or really any other debris... That thing is gonna twist up like a pretzel.
Just planning for raking pine needles mostly. If one side does twist I only have to replace one piece of steel tube and maybe the angle iron.
Also, the hay rake teeth have rubber boots between the tooth and the mounting and that lets them flex pretty good. What little I used it I was watching the steel tube and it didn't look like it twisted and I examined it afterwards and it still looked straight.
.....but time will tell.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #4
Hi Dave,
Nicely done.
I have been contemplating something similar, but for leaves stones, sticks, and branches.
The comments about "immoveable objects" causong damage may be spot on as it sits, but what if you made the rake attachment to the carry-all via a vertical pivot, with or without a spring or springs to apply down-pressure?
The carry-all frame I made has pivots for the horizontal arms so that they can be folded up, and I was envisoning having my rake or rake bars attached across as yours are, but allowing them to continue to pivot upwards to self adjust themselves over uneven ground and to pop up over solid objects.
Do you think that the rake tines you used are stiff enough to pick up stones and sticks?
Thanks forsharing.
Thomas
Hi Dave,
Nicely done.
Thanks forsharing.
Thomas
Thanks for the compliment. I don't think the tines will pick up stones. The whole point with them being somewhat flexible is that they would bend over or around stones. Now, in my trials with it so far it will rake small branches up that are loose on the ground.
I went the other day and bought more tines so I can get them about 3" apart in the hope that it would also work for leaves. Also I have picked up the angle iron and other hardware to make a 3pt hitch to get the elevation needed to get out of the pile I just raked. However, since I've picked the stuff up its been a little cool to be outside building stuff and my shed doesn't have heat. Right now it is 16F with a wind-chill of "OH HE** NO, I'M NOT GOING OUT THERE."
The pivot point and using springs is an interesting idea, but I don't have to stuff to fabricate something like that.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #6
Hi Dave,
You are totally welcome, it is cool.
Thanks for the feeback, I may need some stiffer tines, I'll have to look around.
If I can come up with a pivot, I know that you can, but only if it will work for you.
Thanks again,
Thomas
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #7
Neat.... Some times things made quick and dirty seem to work the best....
If you decide to add another bar and row of teeth, staggered with that set....
Let me tell you from my experience to space the rows at least 10-12" or so...
I tried 6" the first time and it plugged up too quickly and tightly....
Good luck
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #8
Thanks for the information.
How do you get the wheels up out of the way to rake with that setup?
Thomas
Good luck
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #9
Thomas
Looking at the picture it looks like you can pull the wheel out and then turn it 180 degrees and put it back in. Or, the wheels are at the right height so that the tines just touch the ground and then the removal of the wheels might not be necessary.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #10
Your eyes must be better than mind, I couldn't see that at first, but I think you are right, pull those pins and take off the wheels, turn them up, and go to it.
Thanks,
Thomas
Hi Dave,
Thanks again,
Thomas
Thomas,
Here are some options on rake teeth
Tractor Supply Company
Rural King
Agri Supply
On the first two links the one I used is the $1.99 version
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #12
I looked at TSC's rubber based tines, today locally, and they are $2.29 here.
I have also been looking at their other tines, like the ones for hayrakes, but the prices are the same or higher, and it seems like they'd be harder to attach.
Thanks,
Thomas
Thomas,
Rural King
Agri Supply
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #13
Thanks,
Thomas
It looks like the wheels will fit into the front square tube, too. That may let you use the rear teeth only (or some other row), with wheels as depth gauge, with an adjustment of the top link.
Bruce
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #14
Thanks,
Thomas
Here's a picture that kind of shows the attachment of the hay tine rake teeth.
I used the green ones from TSC when I built my dethatcher/rake.
They work great for picking up pine straw but for leaves they could be better. What contributes to this is that the spacing I have them at is to far apart also, as some of the leaves will slip past them. There is a red hay rake tooth that is narrower than the green ones that would probably work a little better for leaves.
Greg
Greg
In your first picture I like the way you hooked up those tines. Do they get cock-eyed during use or do they pretty much stay straight?
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #16
That first picture is one I pulled off of a thread on tbn, not sure where I grabbed it from.
I don't have a good picture of mine on the computer, but you can get an idea from this thread.
http://www.tractorbynet.com/forums/build-yourself/202595-dethatcher.html#post2333291
I used 1 inch angle iron, I think it was, welded to the bottom and attached them so they were butted against one side of the angle. You can kind of see the welded angle in this picture.
This allows them not to get cock-eyed.
Kennyd has a nice close up picture of how he attached his when he built his dethatcher a few yrs ago located here:
http://www.tractorbynet.com/forums/build-yourself/65334-3ph-dethatcher.html#post728530
It will depend on which teeth you use on how you'll need to attach them. Hopefully this will give you some ideas. It sure beats raking leaves by hand. :thumbsup:
Greg
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #17
Thanks Greg!
Thomas
Greg
I've steadily worked, weather permitting, on the mods for my yard/pine needle rake. I added tines to get the spacing to every 3 inches and built a 3pt hitch so I could raise it higher to get it out of the pile of needles I just raked.
1. 20140215_142037.jpg 2. 20140215_142051.jpg 3. 20140215_142119.jpg 4. 20140218_155847.jpg 5. 20140218_155908.jpg 6. 20140219_141713.jpg 7. 20140219_141723.jpg
1., 2., & 3. 3pt hitch I made
4. & 5. rake on tractor
6. &. 7. before raking
8. some raking done
9. after raking
10. pile of pine needles 10ft in diameter and 3ft high. About halfway done on this side of house. I have a pile similar in size on the other side of the house.
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #19
Like in post 14, that is how my 3 rows of times are set up....
With the wheels as they are in the picture, it rakes 3/4" deep... There are 3 holes in the legs, at 1" apart to adjust the wheels up the leg it is on..
Or like said, un-pinned and removed.... The rake assembly bolts to the universal 3pt tool bar... It will also bolt onto the tool bar backwards of what it is in the picture....
It also works well for minor, or finish grooming of the gravel driveway....
Now I just have to build a 3pt lift for the front of my tractor to run the rake out in front of the mower deck....
Keep the good ideas coming....
   / Good landscape rake - cheap (Part 2 - Daver1963's attempt) #20
Wyobuckaroo, I'm planning on "borrowing" most of your rake - here's one change I'll make, since I have a hydraulic toplink -
use BOTH of your crosstubes as anchor points, do a couple of tees into each of them, then some fairly sturdy square tube (on each side) thru those tees, going to the REAR by maybe 2 feet or so - put your gauge wheels back there, use the pin adjustments so that, with the hydraulic toplink RETRACTED, the tines penetrate ground by maybe 3/4" -
Then you have infinite control of "dig" by varying toplink on the fly. You'd still have your 3 point lift to dump, and once you find the "sweet spot" you probably wouldn't have to change the toplink much at all... Steve
(APPROX. 20) 4' X...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
