Rotary Cutter LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS?
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I recently purchased a LAND PRIDE - RCF 2060 Rotary Cutter ($1,600) to pull behind my Kubota L3560.
Land Pride supplied CHEAP Draw Pins are too short to get a boot on, and ROLL PINS for finger grips?
How many customers buying a RCF 2060 will retain the cheap Draw Pins? Approximately zero, I should guess.
WHY SUPPLY INADEQUATE DRAW PINS FROM THE FACTORY ??????
Photo #3 shows ample/generous/over-spec Draw Pins supplied with HOWSE Disc Harrows.
LAND PRIDE: There is no such thing as PARTIAL excellence.
This is my first implement from LAND PRIDE.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #2
Them are pretty cheap pins. I bought a Land Pride rear blade last fall and it is very well built and has very nice cat 1 & cat 2 combo pins. Maybe somebody swapped pins on the dealer lot?
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #3
Same as Underdog57 only I bought my RCR2672 three year ago and it had very good cat 1 and II pins.
According to the Kubota mechanic, who unloads the trucks, that is the way Land Pride RCF 2060s arrive.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #5
I had those junk pins on my Shredder too. Jeff wants me to say" Land Pride Shredder too"
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #6
Those look like the same too-dang-short-pins that come on LP's landplanes.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #7
Now the Pins on my Land Pride Landplane were alright.
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #9
   / LAND PRIDE - RCF 2060 - Rotary Cutter - WHY CHEAP DRAW PINS? #10
If the pin fits the hole and fits the hitch and carries the load, it doesn't seem like a big issue to me....unless I don't understand something here....:2cents:
Utility Trailer (A52377)
Utility Trailer...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2018 John Deere 333G Track Loader (A53485)
2018 John Deere...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2017 BMW 540i Sedan (A55853)
2017 BMW 540i...
