bobcat 2003 334 d series stuck in my driveway, snow piling up
   / bobcat 2003 334 d series stuck in my driveway, snow piling up #1
Heavy D
Qualicum Beach Vancouver Island Canada
Bobcat 2003 334 Mini D Series
pushing snow in my driveway and the machine wont move. code 65-06 "workgroup lockout solenoid short to ground" what's my next move? Where is this solenoid and how do I fix this
   / bobcat 2003 334 d series stuck in my driveway, snow piling up #2
Open the side door cover, below the control valve you will see an aluminum manifold block. Has several hoses and solenoids on it. There are 2 work group solenoids. 1 has a green tie strap around the wires at the plug connection, the other has an orange tie strap. Check ohms on each to see which 1 is shorted, good solenoid should be around 8ohms resistance.
   / bobcat 2003 334 d series stuck in my driveway, snow piling up #3
That is the "answer of the year" :thumbsup: Direct, simple & short. (but it's why I won't part with my mechanicaly controlled machine)
I did get a hold of a manual and located the two solonoids that you are talking about. I unplugged them and the resistance of the green was close to spec and the orange was about half value (3 or 4 ohms) then I tried powering them up with some jumpers to the batt, the green would click when powered, the orange caused a slight arc but no clicking sound. with them powered to the batt I could move the machine and lift the blade. At least I could clear the lot and keep the shop open but no hydraulics for the bucket, arm, or swing...which made a messy plow job. I wouldn't be waisting my $$ by purchasing a solenoid?? I don't suppose you know the part # by chance... Thanks so much
   / bobcat 2003 334 d series stuck in my driveway, snow piling up #5
Without your serial number I can't be 100% but I am fairly certain p/n is 6675351 (just the magnetic coil). On the manifold there should be 1 more solenoid that looks same as the 2 lockouts, this would be the 2 speed. You could move the 2 speed to the failed lockout just to make sure the other functions work fine and code clears. Machine would work except no hi-range. That would verify all you need is a new coil.
You can look up part numbers in online parts catalog in Bobcat's website Home Page - Bobcat Company.
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
