Backhoe Need some pics of the 3710 BH rear couplers
   / Need some pics of the 3710 BH rear couplers #1
alia176
Tijeras, NM
Mahindra 3316HST
Can I see some pics of the holder/bracket that holds the BH couplers please? I'm thinking of adding this to the rear of my 3316 with the 3720B backhoe. Currently, this coupler connection sits behind the engine, under the tractor which I find to be less a than ideal location. I should be able to move the connections to the rear and come up with a better solution.
Those of you not familiar with the 3720B unit, the subframe is part of the BH and the whole thing needs to be dropped when you detach the BH from the tractor.
Thanks.
   / Need some pics of the 3710 BH rear couplers #2
Thanks.
alia, I have the 3710 which I use on my 2615. The 2615 also connects under the tractor not in the rear. Had I had the foresight, I would have had rear remote couplers added at purchase time.
Here is an owner of a 3316 who has already gone through the process: http://www.tractorbynet.com/forums/hydraulics/283227-adding-rear-hyd-mahindra-3316-a.html
Ok, so the 3710 & 3720 both have subframes that are attached to the BH with the coupler connection under the tractor, near the engine.
Anyone else have a different BH with the coupler connections in the rear? I'd love to see some pics! Maybe I'll go the parts catalog for a 3016/3616 and see what they have. I should be able to use their design and make it work on my tractor.
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2011 Case IH Steiger 335 AFS Tractor (A53485)
2011 Case IH...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
Heavy Duty Wheel Balancer Machine (A55852)
Heavy Duty Wheel...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
