Harbor Freight copies StrongHand Nomad welding table...$59
   / Harbor Freight copies StrongHand Nomad welding table...$59 #31
To lengthen the tables and expand total capacity....but most likely a marketing tool.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #32
Beat you to it. I got both this evening. 20% off total purchase ends tomorrow. I haven't assembled the ersatz nomad yet so I don't know how easy it will be to pair with the nomad but it should work. If not, for $48 it might be worth just getting a second one to pair.
The new MIG cart is quite nice. Drawers are smooth and one drawer has lots of compartments for little stuff. Leads and MIG gun can be draped over purpose built holders on either side. Spot for one tank. More compact than the traditional lower and longer cart. Space in the garage is a premium for me and I prefer to have the welder controls higher than on the older style cart too. Older style cart would be more stable wheeling around outdoors but in a garage there is no advantage.
I didn't think the sale started until today (mar 1 ) I hope they will take one of the 20% coupons and not call a foul ball because its a "tool cart". I have the tall open cart and will reuse it for my plasma, i prefer the thin style for space saving maneuverability.
I own both styles. The new HF style is taller but is the same width. It is only about 2/3 or half as deep as the original style. Not as useful if you intend to roll it around outdoors due to wheel size and being top heavy, but the new style makes much more effective use of space.
I guess I am missing something. Why not just reinforce the edge (if it needs it) with a small angle iron, and bolt one table to the other directly? I don't understand the point of the connector plate.
You don't even need to reinforce the edge to connect it to a sister table. You could also use three tables side by side to create a larger work surface. But there are a couple reasons why StrongHand offers the connector. 1) It costs $60 rather than $150. 2) having a connector allows you to sit with your feet underneath without having the support structure interfere with where your feet are. With the HF model, if you really have a need for a 20x90 or 30x60 table, you could just buy a third table for the top.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #35
A guy did a side by side comparison on our site forum with pictures, and even measurements of both. My thoughts are they are probably made in same factory, with minor differences which are probably optional like a height adjustment. Strong Hand Nomad portable welding table review - Page 2
Nice comparison. I saw them today and was tempted to get one. I really wanted the welding cabinet, but they were out. When I go back for the cart I will grab a table too as right now I have nothing to work on but the floor, and this will certaintly be better than nothing.
I like the way that photos are displayed in the pop-up window, so much easier than the way it works here on TBN. I believe both sites are using the same forum software, and I know of another site that does too. I've been told that the pop-up window feature is included and not an add-on, so why don't we have it here I wonder?
Post a question in the news/feedback forum. Not sure they will see your question here. Agree with your point.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #37
I just ordered one from the sale flyer where it is listed at 36lbs.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #38
HF finally had one in stock when I stopped by the new store in Houston yesterday. $59.99 sale price and they accepted a 25% coupon. $45 out the door. I'm thinking about cutting the vertical support tubes on both sides and find sq. tubing that will either fit inside or on outside of present supports to give some height adjustability. For me, it's too short to work standing up.
I wonder if it would be just as easy and more stable to just build a simple platform to put/secure the welding table on. You could get fancy and build some storage into the platform.
   / Harbor Freight copies StrongHand Nomad welding table...$59 #40
Island;
Thinking about buying the HF welding Cabinet below. I already have a cart for Mig machine but, it has little storage.
http://t.harborfreight.com/catalogsearch/result?q=Welding+cabinet
$129.99 on sale. Not sure if they will let you use -25% coupon on it or not? That would get it below $100.
Drawers have ball bearing slides and fit / finish on floor model looks pretty good.
19011 (A48082)
19011 (A48082)
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
