Chain Harrow ???
   / Chain Harrow ??? #1
Odonnks
Member
Kittanning PA
Kioti, Case, Yanmar
Hello all,
When winter subsides I like to get an attachment that will break up all of the horse manure left in the pasture.
Is a chain harrow the correct attachment for this?
Thanks !
   / Chain Harrow ??? #2
I used a 4x4 chain harrow behind my ATV for this purpose. It works well, but I'm planning on getting a bigger harrow to save time. If you're using you're tractor you could essentially get as big of a harrow as you wanted.
   / Chain Harrow ???
Thanks for the feedback !!
   / Chain Harrow ??? #4
i use what they call a chain or drag harrow... it works GREAT at breaking up the horse poop and loosening up the snow mold so the grass grows better.
   / Chain Harrow ??? #5
I know somebody that calls a chain harrow a turd buster:laughing:
   / Chain Harrow ??? #6
Yep, a chain harrow. I asked a similar question on TBN about a year ago. Quite a few responses on various DIY contraptions: weighted tyres chained together; an old steel gate, again weighed down with tyres; etc...
In the end I went ahead and bought an Aussie manufactured one, two 4x4 sections. The first section has tines and the second one is a heavy mesh. I also use it to groom a horse arena from time to time.
Mind you, all that a chain harrow will do in this situation (manure) is to break up the balls and spread it around a bit. I typically follow up harrowing a paddock with my D110 and mulch the spread-out 'goodness'. :)
   / Chain Harrow ??? #8
A few years ago I bought an 8' x 12' chain harrow from a local farmer. It certainly does the job...and quickly...but is a pain to transport, hook up (sometimes untangle!). I think I would have been better off with a narrower one and just take a bit longer on the job.
Bob
   / Chain Harrow ???
Seems like I'm on the right track.
Which ever size I get I was planning on using a 3-pt boom to ease transport and let me raise it to go in reverse if need.
   / Chain Harrow ??? #10
Don't get carried away and get it caught up in the rear wheel. Nasty. I've seen it happen.
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2009 DRAGON PRODUCTS 130BBL VACUUM TANK (A53843)
2009 DRAGON...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
