Kubota MX5100 (HT)
   / Kubota MX5100 (HT) #1
PineOak
Montgomery, TX
Kubota MX5100
I own a Kubota MX5100 w/hydrostatic transmission. I suspect I have a "safety switch" problem, because as of yesterday it won't start. Basically, when I turn the key there is no response. The battery is strong, but there is not even the familiar "click" of power reaching the starter. I know there is a safety switch under the seat and as part of the PTO lever, however both of tested OK. Does anyone know if there are others and/or experienced a similar problem?
   / Kubota MX5100 (HT) #2
Not personally familiar with your tractor model. With that said, if I try to start mine with, for example, the shuttle lever in forward/reverse, it still clicks loudly when the key is turned "on", but won't engage the starter when turned to "start". Nothing I can do will eliminate the loud click when turned to on. Sounds like something other than a safey switch??
If you can think of anything else you need me to test I will. Sorry I can't be more help.
   / Kubota MX5100 (HT) #3
Try rocking the hst pedal. It may not think it's in the neutral position.
Thanks for the advice. Turns out it was a loose wire on the PTO lever's safety switch. 3 hours of staring at it and 5 minutes to fix it.
Thanks to all for the advice. As I mentioned above, it was a loose wire on the PTO lever's safety switch. Quick fix.
   / Kubota MX5100 (HT) #6
Good job, better check the rest of those connections.
Good advice. All are secure. As it turns out, the PTO lever switch was the last one I checked, and the last one to check.
   / Kubota MX5100 (HT) #8
Only 3 hours???? I'm never that quick...... Glad you got it fixed!!!
   / Kubota MX5100 (HT) #9
I chased a similar, it was the GST shuttle neutral safety switch. It's been bypassed ever since, I keep forgetting to order a new one...
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
Walking Floor Trailer (A50322)
Walking Floor...
2025 Unused International MV607 Truck TMA Attenuator Truck (A49461)
2025 Unused...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
