rebuid 743 bobcat hyd. control valve
   / rebuid 743 bobcat hyd. control valve #3
Welcome JWBrown,
What is the complaint?
Leaks?
Creep-down?
Low pressure?
Sticky spool?
   / rebuid 743 bobcat hyd. control valve #4
Welcome to TractorByNet!
I moved your thread to the Construction Equipment forum. :)
   / rebuid 743 bobcat hyd. control valve #5
got any good tricks?
Is it a stacked valve or a monoblock valve.
If the spools do have seals on the shaft, they are there to keep dirt out.
On the stacked valves, you can replace the o-rings between the stacks.
You can't replace spools as they are a precision fit, and the bore of the valve is probably worn.
You can obtain replace valves, that will do the job if they will fit the space allowed.
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2015 BMW 320i Sedan (A53117)
2015 BMW 320i...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2023 ARMOR LITE TRAILER BELLY DUMP TRAILER (A53843)
2023 ARMOR LITE...
