Best propane/ mapp torches for the money?
   / Best propane/ mapp torches for the money? #1
diesel lover
whites town indiana
Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
I bought a propane/ map gas torch from lowes for 50$ and it worked well. I let someone borrow it and it didn't run right. It has a valve to adjust the flame and is self igniting. Its a TS8000 from bernzomatic I believe. Recently it slid off my tool box and the impact messed with the valve. I do not need a oxy act torch set as I have friends at nearby that will let me use theirs. Some day I will have my own but it would not be cost effective for me right now. I use a propane/ map torch for heating and removing bolts/ and nuts, removing decals, melting ice, starting fires and etc.
Can I get a good one at menards for 20$ ? I would like one for work and home/ camping
   / Best propane/ mapp torches for the money? #2
I have a lenox that I am pretty happy with, and it's made in USA. One thing that I would check is that I am pretty sure the heads are different for mapp and propane. If you plan on using mapp, get a torch for mapp. I don't know if it's the mixture or what is the difference.
   / Best propane/ mapp torches for the money? #3
If you are going to use the small disposible tanks they interchange. Blue is propane and yellow is the mapp. I am taking tie rods off today and will use my small Bernzomatic mapp. No need to get the tanks out and drag a hose. Works well on simple copper plumbing projects also.
   / Best propane/ mapp torches for the money? #4
I have the Worthington Pro from Menards. Bougth one for my dad too. Then my sister bought one. So far so good. Only a year on mine, but I use it a lot, mostly for starting fires in the wood stove. Not USA made as I recall, but not China either, someplace funky, if I recall. The one I have has valve to adjust the flame. the ones my family members have don't. Those ones (no valve) were on sale recently for $15 at menards with a cylinder of MAPP, which is normally $7. Not a bad price. Don't think the adjustable ones were on sale, though.
   / Best propane/ mapp torches for the money? #5
Oh, I forgot to mention. If you only want to use propane, you can also use the cylinders designed for Coleman appliances. It's the same thread pattern. I like those because they are short and fat and don't tip as easy.
I have a lenox that I am pretty happy with, and it's made in USA. One thing that I would check is that I am pretty sure the heads are different for mapp and propane. If you plan on using mapp, get a torch for mapp. I don't know if it's the mixture or what is the difference.[/QUOTE
Mapp gas is hotter than propane. It is more or less a mixture of Propane and acetelene. I have been using mapp for years on HD truck lugnuts, automotive ball joints etc. Of course an oxygen/ acet torch set works much better with seized parts.
Mapp gas bottles are eternally the same as a propane bottle. They DO have the same threads and fittings.
On a torch designed for mapp gas, you can also use propane but its risky and unsafe to use a torch designed for propane with mapp gas.
Also my father and I have been refilling 1 pound propane cylinders for use with a 20 gallon tank. Saves a lot of money over time.
I just recently bought 9 bottles of propane at Kroger for a $1 each!! What a deal!
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
PALLET OF (2) THERMOKING TRIPAC UNITS (A50854)
PALLET OF (2)...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
