My 1972 JD 820 is making oil.......help
   / My 1972 JD 820 is making oil.......help #1
cartod
Northern, West Virginia
JD 4066, 1023
I have a 72 deere 820 that the oil level is rising on. Compression check on radiator shows not coolant. Oil doesn't smell like diesel. Can hydraulic fluid get into oil????
   / My 1972 JD 820 is making oil.......help #2
Hyd oil can't get in radiator. I'll bet it's diesel.Since a lot of sulfur has been removed diesel doesn't has the same odor. 1st place to check for fuel leak is lift pump on the side of engine.
Cool. Thanks that's where ill go first....after I drain some oil. Is there another name for the lift pump? cant find it in manual???? injection pump? transfer pump?
   / My 1972 JD 820 is making oil.......help #4
Transfer pump
   / My 1972 JD 820 is making oil.......help #5
I agree with Jim, if the pump leaks to the crankcase that would cause your problem. Hope that is your problem as it is a cheap fix compared to anything else. I bought a replacement from NAPA without the bowl for about $40.
   / My 1972 JD 820 is making oil.......help #6
JD offers a lift pump through A&I also. A-RE27667 Fuel Pump View/Update 41.27 USD
   / My 1972 JD 820 is making oil.......help #7
I was thinking "get that man a bottle and start selling". Oh not really making it just transfering it....Sorry, bad humor
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
