jd 510 ag tractor engine fastener torque specs
   / jd 510 ag tractor engine fastener torque specs #1
Bud Walters
Williams Lake, BC
IHC454
looking for the "exception" to the standard torque specs for the engine on a JD510 tractor
it has a 152CID 3 cylinder diesel, made in france. i need the main bearing cap bolt torque, rod cap bolt torque spec, flywheel bolt spec, head bolt spec and rocker shaft bolt spec
   / jd 510 ag tractor engine fastener torque specs #2
Main bearings - 110 ft lbs
Rod bolts - 60-70 ft lbs
Flywheel - 85 ft lbs
Head Bolts - 110 ft lbs
Rocker shaft - 35 ft lbs
hey thanks . do you happen to have a service book for this tractor or know where i can find one???
   / jd 510 ag tractor engine fastener torque specs #4
   / jd 510 ag tractor engine fastener torque specs #5
Sorry, I dont have a book for the 510. The 152 engine was used in other models that I do have access to. That is where I got the specs.
So is there some way I can get all the pages pertaining to the 152 engine from you, or as in your previous post you would like it better if I purchased the manual ??
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Caterpillar 200 Forklift (A53117)
Caterpillar 200...
1067 (A53342)
1067 (A53342)
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2018 Mazda CX-5 SUV (A51694)
2018 Mazda CX-5...
