Building a redneck spray truck
   / Building a redneck spray truck #1
7879fordman
Gold Member
gillham arkansas
1969 massey 135 and a 2013 m7040hd 4x4 2013 L3800 HST 4x4
Ok using a 1977 f150 4x4 . Going to use a 150-200 gallon tank . And a 6.5 predator engine and a roller pump . Going to probley rig it boom and boomless . Got the bed off the truck today . Bought the engine yesterday. And have pump . Just got to decide the tank size . And figure out the pulley size to gear the motor down .
Any and all help on the pulley sizes is much needed .
A before the bed removal
Sent from my iPhone 5 using TractorByNet
   / Building a redneck spray truck #2
Cool project! What is it that you're spraying? The old truck looks to be in good shape!... although i know looks can be deceiving.
   / Building a redneck spray truck #3
If you Google "pulley calculator" I'm sure you can find something to help figure out what size pulley you need.
Pastures for weeds/trees . And ya its a pretty clean old truck but I have a title issue that I can't seem to get straight . So I can't tag it . Plus I have 4 other 78-79 ford short bed 4x4's that are streetable . And I only have $200 in the truck .
   / Building a redneck spray truck #5
Wow... where I live it's rare to find a 98 with that little rust. :(
It pretty much rust free .
I'm thinking maybe wrong but a 1" pulley on the motor and a 6.5" on the pump . And thoughts on that .
   / Building a redneck spray truck #8
The pulley calculator I found Pulley size and RPM says with those pulleys the pump will turn about 554 rpm with the motor turning 3600 rpm.
That would be about right then . The motors 3600 . And 540-1000 max is the pump rpm .
So now the fun trying to find pulleys to fit the shafts of the motor and pump . Figure the pump will be the hardest it's 15/16" and motors is 3/4" .
Well it looks like I'm going to have to run a 1.75 pulley on the motor since that's the smallest I can find to fit the 3/4" shaft .
And then a 7.75 on the pump . But my problem is the pump shaft is 15/16" and I can only find 7/8" or 1" bore for this pulley . Should I buy the 7/8" bore and bore it out or turn the pump shaft down a 1/16 . Or buy it for a 1" bore and have it a 1/16th loose .
The rpm will be at 800 with that ratio of pulleys . So under the max 1000 rpm of the pump .
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2015 INTERNATIONAL DF677 (A52472)
2015 INTERNATIONAL...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
