Whining noise and power steering shudder on Mahindra 3616
   / Whining noise and power steering shudder on Mahindra 3616 #1
Laffyridge
Troutville, VA
Mahindra 3616
Hey there...invaluable forum!!! Spending WAY TOO much time on here :)
I have a Mahindra 3616 shuttle with only 15 hours...barely had time to use her but looking forward to spring and summer! When I am using it I often hear a whine and then feel a slight shutter in the steering...sometimes I loose power steering but only for a second and it comes right back. I have checked the hydraulic fluid and it's full (checked it on level ground both when it was warmed up and cold). Also moved the steering wheel back and forth for a long time while running to see if there was any air in the lines. Any suggestions? Would hate to have to have dealer come and pick it up when I just got it!
Thanks!
   / Whining noise and power steering shudder on Mahindra 3616 #2
I would check and tighten all of the suction line fittings. Sounds like it is getting air in the system.
Hey Galen thanks so much for your reply! Where do I find those fittings?
   / Whining noise and power steering shudder on Mahindra 3616 #4
There would be several joints in the line from your transmission housing to the hyd filter and on to the hydraulic pump.
   / Whining noise and power steering shudder on Mahindra 3616 #5
I bought a 3616 last fall with 166 hours and it does the same thing every once in a while. The dealer I got it from said it's normal, not a problem.
   / Whining noise and power steering shudder on Mahindra 3616 #7
When was the filter last changed? If this has an inlet filter on the pump & if it is partially plugged it could also cause this problem. Use an OEM filter if it is a inlet filter.
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
1028 (A51572)
1028 (A51572)
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
