L series turf options, can't find info on one set
   / L series turf options, can't find info on one set #1
yamrpt
PA
3540 Cab
I have an old brochure from the 40 series L models that has pictures of 4 or so sets of turfs.
Two golf styles, titan multis, and a set that's like the older late 80's turfs kubota used on their tractors. I believe they are the least wide turf avail. Can't find pictures of these
I'm deciding on these or the multitracs. Would be nice if they lower my 3540 to the ground some too
   / L series turf options, can't find info on one set #2
Here is what I special ordered with my L3940. Had to wait a few weeks for them. Great all around tire. Philip.
   / L series turf options, can't find info on one set #3
When they delivered tractor, they put this used set on until my special order above came in. I think this is what you are talking about. These really do not offer much traction. Philip.
   / L series turf options, can't find info on one set #4
These are the good ones, had them on my L4330 and loved them!
   / L series turf options, can't find info on one set #5
I have these on my 3540, they have been very good tires. I have 1000 commercial hours on the machine, the fronts are just about done, the rears probably have 40% tread left.
Hey there we go, those were the others I was considering. First I seen them on an actual L series.
I thought they might be better than the multitrac as far as (reasonable) traction goes because it's more tractor weight on less surface area. But maybe these are too much weight for those tires
Have a neighbor with an 80's l series that's like a modern sized B series size with those same tread and a hoe, that doesn't have any trouble. But it's all probably just a ton in weight
Thanks for the pics phil
   / L series turf options, can't find info on one set #8
Are those wider than the R4's? What width does it make the tractor from outside to outside on the rear tires?
   / L series turf options, can't find info on one set #9
I cannot compare to the R4's. See attached pic for dimensions. Philip.
   / L series turf options, can't find info on one set #10
It would look to me as if they may be a little wider.
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
WESSEX CRX 240 LOT IDENTIFIER 156 (A53084)
WESSEX CRX 240 LOT...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
Doosan Forklift (A51573)
Doosan Forklift...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
