Hydrostatic transmission
   / Hydrostatic transmission #1
rc44001940
lewiston, Idaho
mahindra/ 2615
I have a 2615 Mahindra tractor. ( Hydrostatic Transmission & Hydrostatic filter) Can i use transmission & hydraulic oil for the transmission or do i have to use hydrostatic transmission oil. Which i heard is quite expensive.
Thank you; if you care to respond to rc44001940@yahoo.com; as i need to now asap.
   / Hydrostatic transmission #2
You need to use the proper fluid. You know that..Most modern CUTS have wet brakes, and you must use a fluid designed for wet brakes. Automatic transmission fluids and hydraulic fluids not designed for wet brakes will cause problems. Hydrostatic transmissions have very precise tolerances and need the proper fluids to operate well. I cannot imagine trying to save a few dollars on fluid to spend hundreds or thousands on repairs..
2011 Crown Victoria Sedan (A51694)
2011 Crown...
NEW Fork Extensions (A53002)
NEW Fork...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
