Oil Drain Plug
   / Oil Drain Plug #1
cjmt29
Pulaski, TN
2013 Workmaster 75
So, I know this is a pretty dumb question, but...where is the oil drain plug on a Workmaster 75. Doing the 50 hour maintenance and got started in dark. I cannot fine the drain plug, though. Any help is appreciated. Thanks.
   / Oil Drain Plug
One in every crowd. I looked there, but the pic wasn't any help.
   / Oil Drain Plug #4
Just a guess, but I think it's item #5 in the image below.
Steve
   / Oil Drain Plug
Thanks. I'll give it a try this afternoon. I guess I was looking for a bolt instead. There is a plug just like that one on other side too. Thanks, again.
   / Oil Drain Plug #6
It's hard to tell from the diagram, but it looks like the Workmaster drain plug has a hex drive head. FWIW, the hex drive head on my TN 55's drain plug is 12mm.
Steve
   / Oil Drain Plug
Thanks a bunch, brother. Mine was probably a 12mm too, but I used a T60. Couldn't find a 12mm anywhere. Thanks, again.---Craig
   / Oil Drain Plug #8
Sears has a 12mm hex key: Sears.com.
You can make a workable driver using a bolt with a 12mm hex head and two nuts (one acting as a jam nut).
Steve
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
