Netwrapping Firewood on Pallets
   / Netwrapping Firewood on Pallets #13
I have see it on semis net wrapped and Saran wrapped . So both work .
Sent from my iPhone 5 using TractorByNet
   / Netwrapping Firewood on Pallets #14
Wonderful thing about this site and some others. Someone may have a question about trying to figure something out and can post or search and another may have already solved the issue. Like the pallet puller mentioned above. Didn't know such a thing existed.
   / Netwrapping Firewood on Pallets #15
I was just thinking the same thing.
   / Netwrapping Firewood on Pallets #16
That sounds interesting. I would like to see a picture of it. I am always looking for ways to improve the way I store firewood. This so far seems like it works good especially since the netwrap is free. I don't know what I'll do when I run out.
Here are what mine look like.
   / Netwrapping Firewood on Pallets #17
My BX will not lift a whole pallet so I cut the pallets in half first. I use some fence slats, or other scrap lumber, for side supports and run a piece of recycled strapping around the top to hold it together.
I cut split and stack on the pallets all in one area.
   / Netwrapping Firewood on Pallets #18
I've used several types of pallets in the past but switched to apple bins this past year. They are low enough to fit under the end of the 3 point splitter we use so split wood falls right in. They don't hold as much loose but rough stacked 6 bins = cord. We stack them 3 high with the loader in the tarp building they are in. When empty 3 bins nest together well.
I thought about adding side supports but they are not stackable like pallets when you don't have wood on them.
Apples bins are hard to get a hold of here. They use them til they aren't worth fixing and then throw them away. Some places are going to plastic apple bins.
   / Netwrapping Firewood on Pallets #20
Those would be the ones I use. I get them from my buddies burn pile at the orchard. Most of time the corners that attach to the pallet are what is damaged. You can cut 1x material to slip in the sides. The edges would damage apples so they don't do this repair but its fine for me.
2010 Chevrolet Traverse SUV (A55758)
2010 Chevrolet...
2-34x15 Tractor Rims (A50775)
2-34x15 Tractor...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54756)
PREDATOR TRI-FUEL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A54607)
2018 HINO 268 NON...
