Missing 777
   / Missing 777 #161
If it were extremists they would have crashed into something to make their point. They are not interested in keeping you guessing. Unless their plan failed and crashed into the ocean. I just can't believe that there isn't a trace of wreckage anywhere.
Why crash an empty aircraft when you can load the aircraft with nasty lethal items of your choice. Then use it as a cruise missile ?
   / Missing 777 #162
Why crash it at all? Every few months, make some "chatter" that causes half the worlds governments to overreact with knee jerk reactions because nobody know where this plane went and everyone's terrified it's going to be turned into a big bomb. They could probably keep that bluff going for a good year or two, causing significant damage to freedoms, budgets and markets everywhere.
   / Missing 777 #163
I have to put your mind at ease on the issue of whether composite construction had anything to do with the disappearance of flight MA370. From a structural-weight standpoint, the 777 is primarily an aluminum airplane. Seventy percent of the overall structure is aluminum, including the wing, wing box and fuselage. The significant composite structure on the 777 are the vertical fin, horizontal stabilizers, and passenger-floor beams which utilize a Boeing/supplier developed toughened, damage-resistant carbon fiber epoxy resin system. These components could not cause a catastrophic break up of the aircraft in such a way that communication/tracking systems would be instantaneously severed such that the aircraft would immediately go 'missing'. I believe I have some credibility on this matter as I was a lead structural engineer on the 777 involved in the composite design from its inception to production and delivery. .
From the access door in the floor of the flight deck into the from avionics compartment. How much access is there to the oxygen system , into the front wheel well and back into the cargo compartments?
What other access hatches are there from the passenger deck down into the lower lever of the airframe?
   / Missing 777 #164
Is everybody aware that the head of the c i a is a hard core Sunni Islam ?
I could not imagine some covert black ops division of the c i a organizing the "borrowing" of MH370?
   / Missing 777 #165
Here is where I am on this subject. The plane was stolen. Terrprists stole it using some of the James Bond type scenarios explained in this thread.
However, US intellegence has also watched James Bond movies. After 9-11, the US has made sure we have a top secret way of tracking all jet engines ... whether the engine is running or not (especially on all US company manufactured planes). Each engine has a unique tracking method. So, we know where the plane is located. THis tracking system is top secret so it can't be "turned-off".
We are using the media to make it seem we are in the dark. We even send ships and search planes out looking for the plane to make it look like we are clueless. But we know where the plane is located.
It is just a matter of time before we can act and not compromise the intellegence. We also need to be sure about the passengers.
Stay tuned. A dramatic ending will occur --- but not until we are ready.
MoKelly
   / Missing 777 #166
Could it be just a distraction to take the media eye and public awareness away from the incredible deception that is being promoted regarding the events in Syria and now the Ukraine?
I see a pattern....
Most of us accept what is presented in the main stream media. Not sure why we do. I suggest looking more deeply. ...if we can.
   / Missing 777 #167
I see a pattern....
We can, we just have to look at the British press or sites like Drudge to see the truth sometimes.
   / Missing 777 #168
I hope this isn't true but some folk claim the 777 avionics bay is accessed through a hatch in the airframe's passenger deck at row four.
Doesn't that open up some possibilities . Time to lock that barn after the horse is gone.
   / Missing 777 #169
I heard something similar. The cockpit, of all things, is accessed through a hatch at the front of the passenger compartment. Can you believe it!?? They better shut down that loophole quick before the bad guys figure it out.
:laughing:
   / Missing 777 #170
The plane!
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
Dayco Val Power Hydraulic Hose Crimper (A50775)
Dayco Val Power...
2022 31 MINI SKID GRAPPLE BUCKET (A55745)
2022 31 MINI SKID...
2016Ford Explorer AWD SUV (A55758)
2016Ford Explorer...
