Buying Advice Need some advice on a new rig
   / Need some advice on a new rig #1
Msarti
Mi
Kubota 3710 HSTC
Hello all, I will be upgrading my 1710 this year for a cab tractor and would like some advice. I live on 13 acres and will be using the tractor to mow and maintain our property and also to plow snow in some apartment and condo parking lots and streets. If anyone uses their CUT to plow, please chime in as to what set up you use. If you have any input on what make, model, hp or snow removal setup that would be great. I currently have turf tires on my 1710 and would like to try industrial tires on my new tractor. I originally had ag tires on the 1710, but they really tore the yard up. I also have a Gravely zero turn to handle most of the mowing duties, so I am considering 35-45 hp.
I am still deciding between spending upwards of 20K for a used unit, or just buying new and financing some of it. I am new to this forum but have owned several tractors over the years. Thanks in advance.
   / Need some advice on a new rig #2
Welcome!
The good thing is that there are a lot of really good machines in that size range, and not many bad ones. One thing to consider when you look at new is that most dealers are in the process of selling the last of the 2013 models that have Tier III emissions, and starting to sell 2014 models with Tier IV emissions (more complicated, more expensive).
Do you know what brands you have within a reasonable distance from you?
As far as plowing, you may want to look in the snow removal section as there are a couple of monster threads on the many different setups people have. After all the snow we got this winter, I'm looking to adapt my truck plow to the FEL, and buy a rear pull style snow thrower...hopefully that will mean the snow goes somewhere else next year!
I looked at tier 3 Kioti dk40 cab and I really liked it. I was quoted 26k plus tax. I want to check out the LS in the XR series.
   / Need some advice on a new rig #4
Both are solid machines, and offer a lot of bang for the buck. Aside from how they feel to you, the only thing I'm aware of to look at with a critical eye is max FEL lift height. The LS has quite a bit less (11") which can be an issue if you're loading dump trucks, etc. My loader is the same, and it's only been an issue when I was filling 30yd rolloff dumpsters, and when I load my neighbors 6-wheel dump truck, but it's still possible. We just put the truck in a low spot to make it easier (it can manage on level ground, but just barely). If I could get LS to change one thing, that would be it. R,
   / Need some advice on a new rig #5
That doesn't sound like a bad price at all on the DK40 with cab. I like LS tractors a lot and it was one of the two finalists when I made my choice. I think the new XR series are Tier 4, aren't they?
   / Need some advice on a new rig #7
One other thing I forgot to mention is that the Kioti and LS tractors match up pretty well feature for feature. The only significant difference I know of is the FEL specs that GManBart mentioned. And Kioti has the 3 point control on the back of the tractor (which is really handy), but LS gives you a second set of hydraulic remotes (Kioti gives you one), so that's about a wash.
I guess the main difference there is that you CAN get a second set of remotes for the Kioti, whereas the external rear 3 point control is not available on the LS (or any other brand that I know of except Kioti).
It would be hard to go wrong with either brand.
   / Need some advice on a new rig #8
It would be nice to try them out with the a cab, one might jump out as the best for you.
Ron
I did drive an Xr46 cab on the lot and I really liked it a lot. The dealer priced it out at 28k plus tax. I also found a very nice Kubota l3540 hstc. It is loaded up with all the bells and whistles with around 1500 hours and the owner will let it go for $15,000 cash. The only problem is no loader. Is that a good enough deal to justify another 3-4k for a FEL? I would save $$9,000 or so going that route, but I would have a used tractor with no warranty. What do you guys think?
   / Need some advice on a new rig #10
If that is with a loader, that is one heck of a price.......It won't be around long.......
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
KMC 5610 (A53084)
KMC 5610 (A53084)
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
