1997 F150 4.6- spark plug blow out
   / 1997 F150 4.6- spark plug blow out #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I was just thinking the other day after hearing about this issue with these motors how fortunate I have been to not have had this happen in 16 years of owning this truck. Spoke too soon. I have found a mechanic 40 miles away that actually put the new motor in my truck in 2009 that is very familiar with the repair needed to provide a permanent fix. I am very hesitant to drive the truck that distance. I feel it may do damage to the cylinder, even if I unplug the fuel injector. Thoughts?
   / 1997 F150 4.6- spark plug blow out #2
I had to get my truck towed and AAA very nicely supplied a nice ramp truck and took it 100 miles to my mechanic. Who knew it was free. I would not drive it at all but that is me.
   / 1997 F150 4.6- spark plug blow out #3
AAA plus will do it, not the standard subscription. It's been worth having it for me. You can even use it for someone else's car and really save the day.
   / 1997 F150 4.6- spark plug blow out #4
My BIL broke a plug 5 years ago on a 5.4 F150. He unplugged the Injector and drove it 3 days before getting it fixed. It will not hurt a thing.
Chris
   / 1997 F150 4.6- spark plug blow out #5
If you look at Timesert (popular aftermarket repair kit sold) repair instructions it states that the plug blow out problem happens on 4, 6, 8, and 10 cylinder Fords from 1993 through 2004!!
Talk about a flat learning curve!!
Some vehicles need the heads removed for access! (motorhomes) You can't JUST remove the cabs on those for access.
   / 1997 F150 4.6- spark plug blow out #6
i fix these quite often, you probabally could drive it... but i wouldnt. just my .02
Chris
The truck is now repaired, $400. This included the recommended repair by Ford and 8 new plugs. The mechanic that did the repair does one of these every few weeks, mainly 99-02 models. Mine is the first 97 he has done. It baffles me that Ford did not release a recall on this. It seems to be a somewhat common issue. It is all over the internet with a couple companies that specialize in this repair. I towed the truck there on our trailer with our new Tundra- pulls real nice.
   / 1997 F150 4.6- spark plug blow out #8
I too have a '97 with the 4.6. So far, so good.
I'm surprised you had this happen as I thought I read somewhere years ago the problem appeared in the larger engines. I MIGHT have read that the problem also appeared in newer (more valves?) versions of the 4.6 engine.
   / 1997 F150 4.6- spark plug blow out #9
It was a bad design but the real issue was people over torqued the plugs. They only need 7 ft lbs. A man can do that with a screw driver.
Chris
Lockwood 24" x 14' Conveyor (A47369)
Lockwood 24" x 14'...
2014 Ford XL 4x4 F-250 Ext. Cab Pickup Truck (A45336)
2014 Ford XL 4x4...
2012 Hyundai Veloster Hatchback (A46684)
2012 Hyundai...
Flail Mower (A47809)
2019 Peterbilt 520 T/A Heil V-1702 28Yd Front Loader Garbage Truck (A45336)
2019 Peterbilt 520...
2002 John Deere 5205 (A47307)
2002 John Deere...
