RCK48-15BX mulching or Gator blades
   / RCK48-15BX mulching or Gator blades #1
Happy Gilmore
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
Hey guys, looking to get some Gator or mulching blades for my RCK48-15BX deck. Any suggestions? No luck on search.
Any thoughts
   / RCK48-15BX mulching or Gator blades #3
I have used the gator blades with good results. Good construction, much improved quantity of discharge out the side. In the fall I run my yard vac considerably less due to the mulching power of the gator blades. Highly recommend. I have the RCK54-23BX deck.
snpower, where do you get yours?
   / RCK48-15BX mulching or Gator blades #5
   / RCK48-15BX mulching or Gator blades #6
Another vote for the Gators.
Cant help you with what model to get because I have a 54P.
You need the measurements of the factory blades to start. Oregon has all their blades listed in their catalog, all you got to do is match what you have with the catalog.
I think they might even have a web ap to select blades... IIRC the model selection is pretty limited and it wouldnt work for me.
Thanks sn and Scooby, I can't seem to find a 48" deck option either. I'll get the exact individual blade specs and check around to see what I can come up with. I tried searching the forum and google for blades for the deck model #, maybe the blade spec will be the ticket.
Scooby, by the way that deck chute blocker you made up sure is nice.
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
(3) Military Front & Rear Differential (A50121)
(3) Military Front...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
