mf 1552 no power
   / mf 1552 no power #1
grizzly101
pennant, sk.
mf 1552
used my 1552 today.shut off and when I came back to restart I have no power. ckd battery it is ok, power to starter,power to fuse by starter but no power to switch,headlites hazards or fuse panel. anybody have any thoughts? ECU?neutral switch?
   / mf 1552 no power #2
Check the negative terminal on the battery maybe? Could have possibly wiggled itself loose, or corroded a bit ...
Otherwise, are all your fuses good?
   / mf 1552 no power
there is no power to the fuse bar. but ther is power to the starter power terminal and the slow burn fuse next to it.
   / mf 1552 no power #4
Battery terminals can look great and still be a problem. Take both off, use round battery brush on terminals and clamps. Then before putting them back on put a good coat of dielectric grease all over them.
   / mf 1552 no power
cleaned both terminals but still nothing. problem is there is no voltage getting to fuse panel thus no ignition, lites etc.
   / mf 1552 no power #6
There should be a slow blow fuse near the battery as well as the slow blow near the starter. The one near the battery feeds the power to the fuse bar and all the accessories. My 1240 has the electrical schematic in the owners manual. If you have your owners manual you should look in it. Short of that you should trace the cable from the battery terminal to all connectors. Disconnect the positive lead from the battery and use a continuity meter to check for an open in the wire harness. I'd start at the slow blow next to the battery.
   / mf 1552 no power
you were right it was slow burn fuse. fuse looked good thru window but was burned. tks. for advice.dont have manual but will order one for the schematics. tks. again
19008 (A56859)
19008 (A56859)
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Lonestar 15 ft dump trailer (A55973)
Lonestar 15 ft...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2014 FREIGHTLINER...
