Ever had a hitch pin or lock fail?
   / Ever had a hitch pin or lock fail? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Spend a period this afternoon wire brushing both of the stainless steel dog bone type hitch bar locks I use, and lubing the lock cylinder and screw-in threads. They are at least ten years old, and aside from surface discoloration and the scuffing of the shank where it connects the receiver hitch and bar, both still look good.
Has anyone ever experienced a failure of a hitch pin or lock because of age....(horizontal shearing)? Someone told me that he replaces his hitch pins every 5 years because he does a lot of class 3 towing and he worries about metal fatigue.
   / Ever had a hitch pin or lock fail? #2
All I can say is I tow a 34 ' TT @ about 10,000 lbs, class 5 towing. I have towed Across the country a few times and local ( within 500 miles) for the last 6 years on same hitch lock pin. If that would be the case how many years would the hitch be good for?
DevilDog
   / Ever had a hitch pin or lock fail? #3
No need to worry about metal fatigue because there is no flexing of the metal. Your friend who replaces his is throwing money out the window. Does he replace every fastener on his vehicle like his lug bolts too? The receiver tube will fail sooner than the pin.
   / Ever had a hitch pin or lock fail? #4
I have the same hitch pin since 1986. I bet it has 250,000 miles on it pulling everything from a log splitter to a 16,000# boat. If you look up the break point of 5/8" steel it's north of 50,000#. I have seen 4 hitches fail, one ball, and about 10 draw bars but never a hitch pin.
Chris
   / Ever had a hitch pin or lock fail? #5
Not to mention the pin is in double shear, which is just about the strongest mechanical mode something made out of steel can be put into... The pin would be the least of my worries...unless it was a Horror Fright or worse version... Even then a failure is highly unlikely..
   / Ever had a hitch pin or lock fail? #6
I have a locking hitch pin, dog bone style. It isn't close to breaking, but I am noticing a little bit of wear right where it rides on the receiver. I haven't replaced it yet because I haven't found the same style to replace it with and I don't like the locking pin I bought for use with our Suburban...When I find this style again I will probably buy 3 or 4 of them.
   / Ever had a hitch pin or lock fail? #8
Found the attached on RV forum. It is from the Draw-Tite catalog and shows their 5/8" dog bone type locking pin rated at 31,000 lbs. shear strength.:thumbsup:
Thanks, that is the style I have and I've really liked it. I might have to look one of those up and order some. At this point it hadn't bubbled to the top of the search list, but it is getting there :D
That's EXACTLY what I have...ordered mine from Camping World back in May of '99....they cost me $11.67 each with my Presidents Club discount...probably be about $30 each today.
   / Ever had a hitch pin or lock fail? #10
I've had them be jerked out (by twigs, etc.) but not sheared.
Even had an oil dipstick be jerked out.
Ralph
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2007 Ford Five Hundred Sedan (A55758)
2007 Ford Five...
New Kivel Skidloader Double Bale Spear (A50775)
New Kivel...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
