Okay TBN Friends... To B or Not to B (Therefore BX).
   / Okay TBN Friends... To B or Not to B (Therefore BX). #51
Yes, there is if the lawn I'd really wet and I turn as tight as posdible. I have about 30 trees to mow around. But I have a very large lawn that I have to go around many times. So I cut back and forth catching an arc around each tree at each pass taking about a third of the circle around the tree. So I don't try to catch the whole circumference in one pass around. I hope that makes sense.
Basically, I work it out so I don't cut real tight and keep it in 2 wd and I'm happy with the results.
I usually cut down one side of my trees and then back up the other side and then back and forth on the other two sides while doing passes going the other direction so often times I never circle the tree. I cut around most of mine this way and I've got a lot of trees. Guess it depends on layout of trees and spacing. GO GO GO!!!:tractor: BUTT AND SMILE!!!:cool2:
   / Okay TBN Friends... To B or Not to B (Therefore BX). #52
I also do some of that.
   / Okay TBN Friends... To B or Not to B (Therefore BX). #53
Not gonna pollute the thread any more.
So you polluted my PM Inbox instead with a lengthy copy/paste, quotations in red, rant stating how wrong I am about the almighty BX and any/all of my comments.As I said in the PM response. You win,,,, the BX is the greatest tractor ever built and I have no idea why anyone would want/need anything more.
   / Okay TBN Friends... To B or Not to B (Therefore BX). #54
For the 4th and last time, I never said anything like that. The only thing I said was that the picture AStanton posted had a nice tractor in it, but the work shown there with some small piles was not impossible to accomplish with a BX. Nothing more. If you can't comprehend simple English, there's no hope for you.
   / Okay TBN Friends... To B or Not to B (Therefore BX). #55
See now you are trying to get personal (can't comprehend simple English). My Dad always said, "wrestle with a pig and all you get is muddy and the pig enjoys it".
You are correct. No hope at all.
   / Okay TBN Friends... To B or Not to B (Therefore BX). #56
Subscribed...trying to condense my thoughts on this first....
Jeez... You must have ALOT of thoughts, or a HUGE head. It sure is taking awhile. Don't know if I can hold on ant longer.
   / Okay TBN Friends... To B or Not to B (Therefore BX). #58
You should let go of the ant... I'm not sure it will survive the wait either.
That's funny. If my phone keypad fit my fingers, it'd look like an iPad.
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
More info coming soon! (A49346)
More info coming...
